Error when installing
bad_vlad123
Hi all - can anybody help with the error(see pic/attachment)
Have installer on a 16GB usb and have a 16GB usb that I am trying to install to.. I do not have any hard drives installed yet, just trying to get the OS installed first.
1x 4u 36 bay 847E16-R1400LP Chassis SAS2-846EL1, X8DTN+ Mother Board
· - Integrated Dual Intel 1000BASE-T Ports
· - Integrated Software Supported RAID
· - Integrated IPMI 2.0 Management
· 2x Intel Xeon E5645 Hex Core 2.4GHz
· 128GB DDR3 (16 x 8GB DDR3 ECC REG)
· 36 3.5" Caddies
· 1x LSI 9211-8i RAID Card
· Dual 10GBE 10 Gigbait Card PCI-E SFP+ HBA Supermicro AOC-STGN-I2S
· dual 1400 PS
Spearfoot
He of the long foot
By any chance, are you using a USB keyboard? Or a keyboard that's a little out-of-the-ordinary?
The dual-CPU Supermicro user on this thread had problems with one:
https://forums.freenas.org/index.php?threads/this-is-driving-me-nuts-kdb-enter-panic.35536/
Looking at the call stack, my guess would be that your panic has something to do with your CPU-related BIOS settings. You might try disabling hyperthreading. But I'm no UNIX panic guru; hopefully one of the experts here will take notice and give us some pointers.
Also, you might want to flash the mobo to the latest BIOS available from Supermicro.
bad_vlad123
I was using a usb key board attached to a USB hub - after getting the error I switched to a ps2 keyboard, with the same result - my motherboard only has 2 usb ports so it made things challenging. I also tried swapping the USB keys - so I put the installer on the second key and tried to install to the first key and vice versa. Still no luck though!
Spearfoot
He of the long foot
Have you configured IPMI on the board? @Mirfster's suggestion of installing FreeNAS using IPMI may be worth trying.
Also, did you do a burn-in of the system? Run Memtest++ and so forth? Check the BIOS version, and upgrade it if needed?
Can you boot anything on the system? DOS from a bootable USB stick or such? Linux from a live CDROM?
bad_vlad123
Not familiar with IPMI, but booting from a live cd sounds like a good test - I will do that tomorrow night and get back with the results. Thanks for the idea!
S
sef
Guest
"Unrecoverable machine check exception". That tends to indicate a hardware problem, although googling for it shows that firmware updates may be warranted.
Puggs
That's a hardware fault on the CPU.
Sent from my Nexus 4 using Tapatalk
bad_vlad123
The computer - posts -so I am not sure its that - but anythings possible at this point. Going to burn in tonight with memtest - do you know of any good boot-able software to test the CPU's?
Puggs
Not directly - have seen the same error on Linux boxes, and there's a program called mcelog that shows details of it
