bad_vlad123
 - May 20, 2016
Hi all, about to build my first FreeNas server. Can someone look over my specs and see if it is compatible or if I am missing something? Not sure if I should be going with a hardware raid card or not. Going to be using 6TB or 8TB Seagate sata enterprise drives. Also not sure if I should go with ZFS2 or Raid6. Server will be used to store and stream 4k content. Both data redundancy and speed are needed. Thank you.
· Supermicro 4U System
· 1x 4u 36 bay 847E16-R1400LP Chassis SAS2-846EL1, X8DTN+ Mother Board
· - Integrated Dual Intel 1000BASE-T Ports
· - Integrated Software Supported RAID
· - Integrated IPMI 2.0 Management
· 2x Intel Xeon E5645 Hex Core 2.4GHz
· 128GB DDR3 (16 x 8GB DDR3 ECC REG)
· No Hard Drive
· 36 3.5" Caddies
· 1x LSI 9211-8i RAID Card
· Dual 10GBE 10 Gigbait Card PCI-E SFP+ HBA Supermicro AOC-STGN-I2S
· dual 1400 PS
· Rail Kit
· No Hard Drive
· 36 3.5" Caddies
· dual 1400 PS
· Rail Kit
