A few days ago, the power supply of my truenas server was failed. After I changed a new power supply, something wrong with one of my raid z1 pool. I can find all of the disks in disks menu but the pool shows offline. I tried to disconnect the pool and reimport it and here comes an error. How can I reimport the pool?
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 371, in import_pool
self.logger.error(
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 365, in import_pool
zfs.import_pool(found, new_name or found.name, options, any_host=any_host)
File "libzfs.pyx", line 1095, in libzfs.ZFS.import_pool
File "libzfs.pyx", line 1123, in libzfs.ZFS.__import_pool
libzfs.ZFSException: I/O error
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1411, in import_pool
await self.middleware.call('zfs.pool.import_pool', pool['guid'], {
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1241, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1206, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1212, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1139, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor
libzfs.ZFSException: ('I/O error',)
