Error updating Plex
Did you try installing it?
pkg install libarchive
If its installed you might just need a symlink..
ln -s /usr/lib/libarchive.so /usr/lib/libarchive.so.6
goomer1979
tried that from the shell for plex and get:
ln /usr/lib/libarchive.so.6 : Read Only File system
Tried from the main shell and get
ln /usr/lib/libarchive.so.6: File Exists
Maybe try a reforce reinstall all packages and depends. Something got wonky somewhere.
pkg upgrade -f
goomer1979
I have managed to sort it by reinstalling truenas on the drive and taking over the existing disks.
Thanks
NealNye
I had the exact same issue after updating my jails after upgrading FreeNAS to TrueNAS. Found this thread by searching
ld-elf.so.1: Shared object "libarchive.so.6" not found, required by "pkg"
in Google...
Did a bit more digging and found this bug which shows the solution is simply pkg-static install -f pkg
