OctaneZ
 - Aug 6, 2011
I had a fully functioning transmission-2.51-amd64, upgraded using the FreeNAS-8.3.0-RELEASE-x64.GUI_Upgrade, and then subsequently upgraded transmission-2.61-amd64.pbi.
The jail looks fine, but starting transmission from Control Services --> Plugins -> Transmission 2.61 fails silently, nothing in /var/log/messages, or /var/log/messages in the JAIL, or in /var/log/transmission.log in the JAIL.
JEXEC'ing into the jail I can see my settings.json file and it looks fine.
When I try to start transmission manually I get:
Any ideas?
Plugin# ./transmission-daemon /libexec/ld-elf.so.1: Shared object "libevent-2.0.so.6" not found, required by "transmission-daemon" Plugin#
Any ideas?
Plugin# find . -name ld-elf.so.1 ./usr/libexec/ld-elf.so.1 ./libexec/ld-elf.so.1
Plugin# find . -name libevent-2.0.so.6 ./usr/pbi/transmission-amd64/lib/event2/libevent-2.0.so.6 ./mnt/plugins/pbi/transmission-amd64/lib/event2/libevent-2.0.so.6
[benc@fourslot] /mnt/fourslot-data/benc# jexec 1 usr/pbi/transmission-amd64/bin/transmission-daemon /libexec/ld-elf.so.1: Shared object "libevent-2.0.so.6" not found, required by "transmission-daemon"
