I installed FreeNAS using the USB method a few days ago. Install went without a hitch and got as far as setting up a volume and users; no shares yet. Left the machine on over night and the next day I there was an error showing after accessing the web page. No, I didn't get the error that was in the web page. I know bad move. However, I restated the system figuring a restart may work out. It didn't FreeNAS wouldn't complete the load. Not that I understand alot that popped up on the screen but the one area that kept scrolling or working over and over was the following:
(ada4: ata 5:0:0:0) Synchronize cache failed
GEOM: ada4: the secondary GPT table is corrupt or invalid
GEOM: ada4: using the primary only - recovery suggested.
FreeNAS ran this over and over I assume trying to get it to work. I tried to start FreeNAS in safe made up it got to a point and never when any further. So, I tried starting it with verbose so I could see more and the above was the same. It just kept trying. I haven't run a hard drive check to see if any of the drives may be at fault as they are new (WD Red 1TB). Will do once I return; school is calling. Thanks for any suggestions.
