Phil Demand
- Sep 13, 2013
From time-to-time, I'll power up the monitor that is attached to my NAS and there is always a long list of what appears to be error messages. I don't know if they are normal, but they look pretty nasty. I'll just give an example of one.
afp_disconnect: primary reconnect failed
To be clear, everything appears to operate normally. Time machine is backing up normally, watching content on my AppleTV through XBMC is working normally. Occasionally content won't load in XBMC, but after I restart my NAS, everything works normally.
Here's my setup:
Freenas 9.1.1 x64
Asrock FM2A85X Extreme6
AMD A4-4000 APU
4GB non-ecc
4 1TB Western Digital Red drives in RAID-Z
Macbook Pro
Hope you can shed some light on this, and/or tell me if I should be concerned about this. Thanks.
P.S. I am aware that this system may not be ideal for Freenas. This system was built for another purpose, by someone else, and then given to me. I then repurposed it as my NAS. Obviously, this motherboard/CPU is lacking in some ways and at the same time contains capability that can never be utilized. And, of course, I should be using ECC. I get that.
Here's my setup:
Freenas 9.1.1 x64
AMD A4-4000 APU
4GB non-ecc
Macbook Pro
