Hi. have little problem with my FreeNAS machine.
are beginners in server and FreeBSD. Have most just run plugins but do not work like I wanted so start following different setups found on different forums beginning everything went stable for half a year since I started my FreeNAS machine installed about it a number of times. Now for a tag, I update from 11.1 to 11.1 U1 and nothing seems to proceed well. do not do anything on iocage is unable to find any python 3.6. Then when you have done your own jails setup, you can not start any plugins that are wrong with mtree! and then today, I would see if there was any updating, then I got the wrong one there to miss Python 3.6 again.
Error messages are linked to the bottom of the page
and a question to how to do this? (The FreeBSD source tree must be located at $ SRC_BASE (/ usr / src by default) to build from git.)
excuse my bad spelling in English
Thank you in advance for all the tips and advice
SINCERELY
and late that it always announces that
SINCERELY
freenas daemon [3742]: 2018/02/02 13:26:54 [WARN] Agent: Check 'freenas_health' is now warning (spam every two minutes) python3.6: dnssd_clientstub DNSServiceRefSockFD called with invalid DNSServiceRef 0x81fe1a120 FFFFFFFF DDDDDDDD Feb 2 11:14:35 NASty python3.6: dnssd_clientstub DNSServiceRefSockFD called with invalid DNSServiceRef 0x81fe1a120 00000000 00000000 Feb 2 11:14:35 NASty python3.6: dnssd_clientstub DNSServiceProcessResult called with invalid DNSServiceRef 0x81fe1a120 00000000 00000000
