chuckthetekkie
- Oct 25, 2021
When I try to import my ZFS pool I get the following error:
zpool history:
Not sure what this means as all 5 HDDs in my raidz2 pass S.M.A.R.T.
Before I got these I got a bunch of errors about "vm_fault: pager read error" and checksum errors and df_complext-reserved errors. Then the TrueNAS VM stopped working so I did a restart and I can't import the pool.
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 371, in import_pool self.logger.error( File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__ File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 365, in import_pool zfs.import_pool(found, new_name or found.name, options, any_host=any_host) File "libzfs.pyx", line 1095, in libzfs.ZFS.import_pool File "libzfs.pyx", line 1123, in libzfs.ZFS.__import_pool libzfs.ZFSException: I/O error """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1421, in import_pool await self.middleware.call('zfs.pool.import_pool', pool['guid'], { File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1219, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1146, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1120, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) libzfs.ZFSException: ('I/O error',)
zpool history:
the configuration database and will be reset on reboot. root@truenas[~]# zpool history History for 'boot-pool': 2021-09-29.01:47:45 zpool create -f -o cachefile=/tmp/zpool.cache -O mountpoint=none -O atime=off -O canmount=off boot-pool ada2p2 2021-09-29.01:47:45 zfs set compression=on boot-pool 2021-09-29.01:47:45 zfs create -o canmount=off boot-pool/ROOT 2021-09-29.01:47:48 zfs create -o mountpoint=legacy boot-pool/ROOT/default 2021-09-29.01:48:38 zpool set bootfs=boot-pool/ROOT/default boot-pool 2021-09-29.01:49:27 zfs set beadm:nickname=default boot-pool/ROOT/default 2021-09-29.01:49:27 zfs snapshot -r boot-pool/ROOT/default@2021-09-29-05:49:27 2021-09-29.01:49:27 zfs clone -o canmount=off -o mountpoint=legacy boot-pool/ROOT/default@2021-09-29-05:49:27 boot-pool/ROOT/Initial-Install 2021-09-29.01:49:32 zfs set beadm:keep=True boot-pool/ROOT/Initial-Install 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-09-29.01:50:11 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-09-29.01:50:12 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-09-29.01:50:12 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-09-29.04:31:16 zfs destroy -r boot-pool/.system 2021-09-29.04:42:43 zfs set beadm:nickname=Initial-Install boot-pool/ROOT/Initial-Install 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-09-29.04:46:01 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-09-29.04:46:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-09-29.07:50:02 zfs destroy -r boot-pool/.system 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-09-29.07:53:36 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-09-29.07:53:38 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-09-29.11:26:02 zfs destroy -r boot-pool/.system 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-09-29.11:34:53 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-09-29.11:34:54 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-10-15.08:12:45 zfs destroy -r boot-pool/.system 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-10-15.08:17:02 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-10-15.08:17:04 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-10-15.08:37:25 zfs destroy -r boot-pool/.system 2021-10-15.09:07:24 zfs set org.freebsd.ioc:active=no boot-pool 2021-10-16.03:45:06 zpool scrub boot-pool 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e476a87416dae61f74d2047f68f 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/configs-6db47e476a87416dae61f74d2047f68f 2021-10-20.00:54:14 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/webui 2021-10-20.00:54:18 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/services 2021-10-22.00:03:56 zfs destroy -r boot-pool/.system 2021-10-23.03:45:06 zpool scrub boot-pool 2021-10-25.02:40:42 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system 2021-10-25.02:40:42 zfs create -o mountpoint=legacy -o readonly=off -o quota=1G boot-pool/.system/cores 2021-10-25.02:40:42 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/samba4 2021-10-25.02:40:42 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/syslog-6db47e476a87416dae61f74d2047f68f 2021-10-25.02:40:42 zfs create -o mountpoint=legacy -o readonly=off boot-pool/.system/rrd-6db47e4
