unorthodox
- Jan 31, 2015
Hello everyone!
I received an error while trying out TrueNAS-SCALE-21.08-BETA.1 and attempting to Export/Disconnect a pool using the GUI. I'm not really concerned about getting rid of the pool, I could probably figure something out eventually. But I wasn't sure if this is an error that should be reported, if I did something stupid, or if I'm missing something obvious.
The chain of events that led to this is:
- I was curious about native OpenZFS encryption nearly a year ago and created a pool with an encrypted dataset on an Ubuntu Server system.
- I recently replaced Ubuntu with TrueNAS-SCALE-21.08-BETA.1 and imported the pool successfully.
- I attempted to "Export/Disconnect" the pool using the web interface and received the error "Error exporting/disconnecting pool."
- I rebooted the system, did not unlock the encrypted dataset this time, made sure no shares were active, made sure no scrub was happening, and no applications are installed. I tried to "Export/Disconnect" the pool again and once again got an error:
[EFAULT] pool or dataset is busy
Motherboard: Supermicro X10SL7-F
CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz
RAM: 32GB with ecc
Boot drive: Corsair 120 GB SSD
HDD: 4x WD Red WD40EFRX 4TB in RAIDZ2
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 142, in do_delete
zfs.destroy(name, force=options['force'])
File "libzfs.pyx", line 404, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 1340, in libzfs.ZFS.destroy
libzfs.ZFSException: pool or dataset is busy
File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 97, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1098, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 147, in do_delete
raise CallError(str(e), errno_)
middlewared.service_exception.CallError: [EFAULT] pool or dataset is busy
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 382, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 418, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1182, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1092, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1636, in export
await self.middleware.call('zfs.pool.delete', pool['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1305, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1262, in _call
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 849, in delete
rv = await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1270, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1276, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1203, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1177, in run_in_executor
await self.future
RAM: 32GB with ecc
