YTKColumba
- Jan 1, 2012
Hello, I am having a little problem copying files to FreeNAS ZFS volume. Below are my spec for my machine.
OS: ESXi 5 (FreeNAS as VM)
CPU: 3930K (2 Logical CPU @ 3.2GHz)
Memory: 8GB
Hard Drive: 9 Disk ZFS RAID-Z2 (9 Datastore on VM and 2TB each, FreeNAS read it @ 13.6 TB)
FreeNAS Version: 8.0.2
Pretty much FreeNAS is a new install and I left most settings to default (new to FreeNAS). I only created the ZFS volume and share it as CIFS.
I am trying to copy about 12GB of information (about 50 files) at once to FreeNAS and sometime I would encounter an error stating drive not available.
- If I hit "Try Again" it would eventually finish copying all the files.
- If I copy small chunk at a time, there would be no error.
I took a look at look at the Performance on the vSphere Client, and it looks like FreeNAS hit pretty much max resource during the copy of the 12GB of files. So I was wondering if I need to allocate more resource to the machine. Or if there are any settings I need to configure to fix this? Or if there are anyway to cap resource usable to a certain point?
Apologies for the long post, I just started to use FreeNAS.
Thanks in advance.
Memory: 8GB
Thanks in advance.
