FreeNAS-LinuxUser
- Jan 17, 2019
After an electric short in my house the NAS a HP ProLiant MicroServer Gen8, didn't boot anymore. After installing a display and keyboard it worked again. Now in the GUI of FreeNAS-11.3-U5 I have three new error messages:
and
and
I searched the problem and found this guide:
So I ssh-ed into the NAS and ran
then
Result:
Since that did not return an "LBA_of_first_error" like in the guide i dont know how to proceed further.
If it helps I did the same procedure with the boot drive. An SSD inside an USB-case.
Any help is appreciated.
CRITICAL Device: /dev/ada3, 16 Currently unreadable (pending) sectors. Wed, 15 Sep 2021 05:13:01 AM (Europe/Berlin)
and
CRITICAL Device: /dev/ada3, 16 Offline uncorrectable sectors. Wed, 15 Sep 2021 05:13:01 AM (Europe/Berlin)
and
CRITICAL Device: /dev/ada3, Self-Test Log error count increased from 0 to 1. Fri, 24 Sep 2021 08:51:11 AM (Europe/Berlin)
http://bytesandbolts.com/fixing-freenas-error-currently-unreadable-pending-sectors/
smartctl -t long /dev/ada3
then
smartctl -a /dev/ada3
Result:
root@freenas[/]# smartctl -a /dev/ada3
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p14 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Archive HDD
Device Model: ST8000AS0002-1NA17Z
Serial Number: Z8407BHM
LU WWN Device Id: 5 000c50 07bbbb83a
Firmware Version: AR13
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 5980 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Sep 29 14:58:10 2021 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 114) The previous self-test completed having
the read element of the test failed.
data collection: ( 0) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 946) minutes.
Conveyance self-test routine
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 176851216
3 Spin_Up_Time 0x0003 090 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 061 061 020 Old_age Always - 40050
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 064 051 030 Pre-fail Always - 7631679121406
9 Power_On_Hours 0x0032 053 053 000 Old_age Always - 41611
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 152
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 12885098499
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 065 058 045 Old_age Always - 35 (Min/Max 34/39)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1667
193 Load_Cycle_Count 0x0032 079 079 000 Old_age Always - 43870
194 Temperature_Celsius 0x0022 035 042 000 Old_age Always - 35 (0 19 0 0 0)
195 Hardware_ECC_Recovered 0x001a 118 099 000 Old_age Always - 176851216
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 16
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 16
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 41085 (221 183 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 63053642690
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 525080289507
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 20% 41523 -
# 2 Extended offline Aborted by host 20% 41512 -
# 3 Extended offline Completed: read failure 20% 41485 -
# 4 Short offline Completed without error 00% 26773 -
# 5 Short offline Completed without error 00% 26772 -
# 6 Short offline Completed without error 00% 26771 -
# 7 Short offline Completed without error 00% 26770 -
# 8 Short offline Completed without error 00% 26769 -
# 9 Short offline Completed without error 00% 26768 -
#10 Short offline Completed without error 00% 26767 -
#11 Short offline Completed without error 00% 26766 -
#12 Short offline Completed without error 00% 26765 -
#13 Short offline Completed without error 00% 26764 -
#14 Short offline Completed without error 00% 26763 -
#15 Short offline Completed without error 00% 26762 -
#16 Short offline Completed without error 00% 26761 -
#17 Short offline Completed without error 00% 26760 -
#18 Short offline Completed without error 00% 26760 -
#19 Short offline Completed without error 00% 26758 -
#20 Short offline Completed without error 00% 26757 -
#21 Short offline Completed without error 00% 26756 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Since that did not return an "LBA_of_first_error" like in the guide i dont know how to proceed further.
root@freenas[/]# smartctl -a /dev/da0
Device Model: LITEON IT LST-32S9G-HP
Serial Number: 002443120486
LU WWN Device Id: 5 002303 1002ff384
Firmware Version: 9401
User Capacity: 32,017,047,552 bytes [32.0 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: < 1.8 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Sep 29 17:16:48 2021 CEST
See vendor-specific Attribute list for marginal Attributes.
Offline data collection status: (0x02) Offline data collection activity
been run.
capabilities: (0x51) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
power-saving mode.
recommended polling time: ( 35) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SMART Attributes Data Structure revision number: 32
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2231
11 Unknown_SSD_Attribute 0x0022 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 984
170 Unknown_Attribute 0x0033 100 100 005 Pre-fail Always - 0
171 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
173 Unknown_Attribute 0x0033 100 100 005 Pre-fail Always - 324
174 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 88
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 2769
190 Airflow_Temperature_Cel 0x0022 055 055 055 Old_age Always FAILING_NOW 45
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0022 100 100 000 Old_age Always - 0
241 Total_LBAs_Written 0x0003 100 100 000 Pre-fail Always - 196366
242 Total_LBAs_Read 0x0003 100 100 000 Pre-fail Always - 269512
No Errors Logged
# 1 Extended offline Completed without error 00% 183 -
# 2 Short offline Completed without error 00% 176 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
