dudemanbacon
- Jun 11, 2014
I'm messing around with virtual machines and getting the following error while trying to create one. This is my home FreeNAS, so this is not an enterprise environment. I did run into issues while upgrading to version 11.2 BETA 1 and had to migrate my phython DB manually as suggested by cipehr in this post: https://forums.freenas.org/index.php?threads/11-2-beta-1-login-issues.68448/page-2. I am not sure if this is related to the failure or not. Does anyone have any idea how I can fix this issue? I've searched the forums for this error and am not finding a solution. Thanks in advance.
OS Version:
FreeNAS-11.2-MASTER-201809110900
(Build Date: Sep 11, 2018 12:13)
Processor: Intel(R) Xeon(R) CPU E5540 @ 2.53GHz (16 cores)
Memory: 20 GiB
ERROR when creating VM:
File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute
return self.cursor.execute(sql, params)
File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute
execute = self.locked_retry(Database.Cursor.execute, query, params)
File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry
rv = method(self, *args, **kwargs)
sqlite3.OperationalError: table vm_device has no column named order
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 155, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1033, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 973, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 278, in create
f'{self._config.namespace}.create', self, self.do_create, [data]
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1022, in do_create
raise e
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1010, in do_create
await self.middleware.call('datastore.insert', 'vm.device', device)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1037, in call
return await self._call(name, serviceobj, methodobj, params, app=app, pipes=pipes, io_thread=True)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 987, in _call
return await run_method(methodobj, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 933, in run_in_thread
return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 219, in insert
obj.save()
File "/usr/local/lib/python3.6/site-packages/django/db/models/base.py", line 796, in save
force_update=force_update, update_fields=update_fields)
File "/usr/local/lib/python3.6/site-packages/django/db/models/base.py", line 824, in save_base
updated = self._save_table(raw, cls, force_insert, force_update, using, update_fields)
File "/usr/local/lib/python3.6/site-packages/django/db/models/base.py", line 908, in _save_table
result = self._do_insert(cls._base_manager, using, fields, update_pk, raw)
File "/usr/local/lib/python3.6/site-packages/django/db/models/base.py", line 947, in _do_insert
using=using, raw=raw)
File "/usr/local/lib/python3.6/site-packages/django/db/models/manager.py", line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1045, in _insert
return query.get_compiler(using=using).execute_sql(return_id)
File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 1054, in execute_sql
File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise
raise value.with_traceback(tb)
django.db.utils.OperationalError: table vm_device has no column named order
OS Version:
Memory: 20 GiB
raise e
obj.save()
