Error creating a jail through command line
NinthWave
Up to now, I have been creating jails using the GUI but I'd like to better my skills is CLI so I tried to create a GUI equivalent of a clone jail with no success.
root@truenas[~]# iocage create -B -n seafile -r 12.2-RELEASE ip4_addr="vnet0|10.0.0.9/24" defaultrouter="10.0.0.1" vnet="on" allow_raw_sockets="1" boot="on"
seafile successfully created!
No default gateway found for ipv6.
* Starting seafile
  + Started OK
  + Using devfs_ruleset: 1003 (iocage generated default)
ELF interpreter /libexec/ld-elf.so.1 not found, error 2
  + Configuring VNET FAILED
Stopped seafile due to VNET failure
Alecmascot
The only difference I see to the command line I use is that I use a lowercase -b to create a base jail, and I have boot="on".
The jail has been created but fails to start.
If you search the forum for the missing file you will see how others resolved this.
Maybe your installation is corrupted in some way.
NinthWave
That is the option I want I believe. Jeez CORRUPTED ? This is worrying.
Can you get it to work with DHCP instead of specifying an address?... I know that it's complicated to set an IP from CLI (but I never bothered to figure it out as I use DHCP static assignments on my network).
Well, even with that, I was just able to do this:
root@nas:~ # iocage create -n "test" -B -r 12.2-RELEASE ip4_addr="192.168.0.2/24" defaultrouter="192.168.0.1" vnet="on" allow_raw_sockets="1"
test successfully created!
