Error After Scrub
SW77
The past few times my pool has been scrubbed I get an email like this.
FreeNAS @ FreeNAS.local
New alerts:
* Pool ZFS state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Current alerts:
* Pool ZFS state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected."
So that lead me to run a zpool status check, here are the results.
root@FreeNAS[~]# zpool status -v
  pool: ZFS
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 0 days 07:46:16 with 1 errors on Thu Aug 15 09:46:18 2019
        ZFS                                             ONLINE       0     0 1
          raidz1-0                                      ONLINE       0     0 2
            gptid/717db7af-7fd5-11e9-954f-d05099c2bf97  ONLINE       0     0 0
            gptid/78e332bd-7fd5-11e9-954f-d05099c2bf97  ONLINE       0     0 0
            gptid/83012eca-7fd5-11e9-954f-d05099c2bf97  ONLINE       0     0 0
            gptid/8a6bb3cc-7fd5-11e9-954f-d05099c2bf97  ONLINE       0     0 0
        /mnt/ZFS/Security/Front_Yard_Camera/2019-08-03/001/dav/20/20.28.30-20.28.54[M][0@0][0].mp4
They strange thing is after I destroyed the pool and restored it from a backup as instructed in the above code, I have a different file that it is saying is bad. What would be a good strategy to figure out what is causing my problem? I have run memtest and it came back with 0 errors.
Thanks!
This seems like the time to ask for SMART data.
SW77
SMART Data as requested
root@FreeNAS[~]# smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     HGST Deskstar NAS
Device Model:     HGST HDN724040ALE640
Serial Number:    PK2334PEGYH7DT
LU WWN Device Id: 5 000cca 250cd67f7
Firmware Version: MJAOA5E0
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Aug 16 16:39:58 2019 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   24) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 559) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   136   136   054    Pre-fail  Offline      -       80
  3 Spin_Up_Time            0x0007   126   126   024    Pre-fail  Always       -       612 (Average 614)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       207
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   121   121   020    Pre-fail  Offline      -       34
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       32454
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       207
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       727
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       727
194 Temperature_Celsius     0x0002   157   157   000    Old_age   Always       -       38 (Min/Max 19/43)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     32344         -
# 2  Extended offline    Completed without error       00%     32259         -
# 3  Short offline       Completed without error       00%     32176         -
# 4  Short offline       Completed without error       00%     31938         -
# 5  Extended offline    Completed without error       00%     31857         -
# 6  Short offline       Completed without error       00%     31772         -
# 7  Short offline       Completed without error       00%     31604         -
# 8  Extended offline    Completed without error       00%     31519         -
# 9  Short offline       Completed without error       00%     31436         -
#10  Short offline       Completed without error       00%     31220         -
#11  Extended offline    Completed without error       00%     31137         -
#12  Short offline       Completed without error       00%     31054         -
#13  Short offline       Completed without error       00%     30886         -
#14  Extended offline    Completed without error       00%     30801         -
#15  Short offline       Completed without error       00%     30718         -
#16  Short offline       Completed without error       00%     30478         -
#17  Short offline       Completed without error       00%     30187         -
#18  Extended offline    Completed without error       00%     30102         -
#19  Short offline       Completed without error       00%     30019         -
#20  Short offline       Completed without error       00%     29803         -
#21  Extended offline    Completed without error       00%     29719         -
root@FreeNAS[~]# smartctl -a /dev/ada1
Serial Number:    PK2334PEGX4DST
LU WWN Device Id: 5 000cca 250cccaf3
Local Time is:    Fri Aug 16 16:40:54 2019 EDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 563) minutes.
  2 Throughput_Performance  0x0005   137   137   054    Pre-fail  Offline      -       78
  3 Spin_Up_Time            0x0007   127   127   024    Pre-fail  Always       -       607 (Average 610)
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       32453
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       756
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       756
194 Temperature_Celsius     0x0002   171   171   000    Old_age   Always       -       35 (Min/Max 20/41)
No Errors Logged
# 3  Short offline       Completed without error       00%     32175         -
# 4  Short offline       Completed without error       00%     31937         -
# 5  Extended offline    Completed without error       00%     31856         -
# 6  Short offline       Completed without error       00%     31771         -
# 7  Short offline       Completed without error       00%     31603         -
# 9  Short offline       Completed without error       00%     31435         -
#10  Short offline       Completed without error       00%     31219         -
#11  Extended offline    Completed without error       00%     31136         -
#12  Short offline       Completed without error       00%     31053         -
#13  Short offline       Completed without error       00%     30885         -
#14  Extended offline    Completed without error       00%     30800         -
#15  Short offline       Completed without error       00%     30717         -
#16  Short offline       Completed without error       00%     30477         -
#17  Short offline       Completed without error       00%     30186         -
#18  Extended offline    Completed without error       00%     30101         -
#19  Short offline       Completed without error       00%     30018         -
#20  Short offline       Completed without error       00%     29802         -
#21  Extended offline    Completed without error       00%     29718         -
root@FreeNAS[~]# smartctl -a /dev/ada2
Serial Number:    PK2334PEGYDKGT
LU WWN Device Id: 5 000cca 250cd5dec
Local Time is:    Fri Aug 16 16:42:12 2019 EDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 603) minutes.
  2 Throughput_Performance  0x0005   137   137   054    Pre-fail  Offline      -       79
  3 Spin_Up_Time            0x0007   123   123   024    Pre-fail  Always       -       623 (Average 630)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       947
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       947
194 Temperature_Celsius     0x0002   153   153   000    Old_age   Always       -       39 (Min/Max 19/44)
No Errors Logged
# 1  Short offline       Completed without error       00%     32343         -
# 2  Extended offline    Completed without error       00%     32258         -
# 8  Extended offline    Completed without error       00%     31518         -
root@FreeNAS[~]# smartctl -a /dev/ada3
Serial Number:    PK2334PEGX7N4T
LU WWN Device Id: 5 000cca 250ccd71b
Local Time is:    Fri Aug 16 16:43:00 2019 EDT
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 568) minutes.
  3 Spin_Up_Time            0x0007   125   125   024    Pre-fail  Always       -       614 (Average 620)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       953
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       953
194 Temperature_Celsius     0x0002   166   166   000    Old_age   Always       -       36 (Min/Max 19/42)
No Errors Logged
# 3  Short offline       Completed without error       00%     32174         -
# 4  Short offline       Completed without error       00%     31936         -
#11  Extended offline    Completed without error       00%     31135         -
#12  Short offline       Completed without error       00%     31052         -
#13  Short offline       Completed without error       00%     30884         -
#15  Short offline       Completed without error       00%     30716         -
#17  Short offline       Completed without error       00%     30185         -
#19  Short offline       Completed without error       00%     30017         -
#20  Short offline       Completed without error       00%     29801         -
tfran1990
Holy fuck your drives are hot.
SW77
Could they really be THAT hot? Or is that a false reading
You should normally expect drives to be kept under 35 celcius, so seeing temperatures in the 40s is a little unusual, but these are 7200 RPM drives and will likely be hard to keep under 40 while spinning and working .
All looks good to me for those HGST drives. You could consider your airflow and see if you can improve it a bit.
You should start having a look into cabling and power as CRC errors can come from that and we've ruled out the drives themselves as the source.
SW77
Thanks, I will check cables and turn the fans up if I can..
