Error add Disk Web GUI
felipesecure
Hi All,
we have 3 servers with same configuration, but via CLI all disk work fine, create via zpool etc, but via GUI not working.
  • Motherboard make and model
    Intel x10drh-it
  • CPU make and model
    Intel(R) Xeon(R) CPU E5-2603 v3 @ 1.60GHz
  • RAM quantity
    16Gb RAM
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives
    16 Drives 1.2TB SAS
    6 Drives 1.8TB SAS
  • Hard disk controllers
    AVAGO Mega RAID
  • Network cards
    2x Dual 10Gbit SFP+
    2x Dual 10Gbit RJ45
    Problem:
    We look into many treahds on this forum and other, but occur that on CMD show disks:
  • lsblk
    NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
    sda 8:0 0 1.1T 0 disk
    sdb 8:16 0 1.1T 0 disk
    sdc 8:32 0 1.1T 0 disk
    sdd 8:48 0 1.1T 0 disk
    sde 8:64 0 1.1T 0 disk
    sdf 8:80 0 1.1T 0 disk
    sdg 8:96 0 1.1T 0 disk
    sdh 8:112 0 1.1T 0 disk
    sdi 8:128 0 1.1T 0 disk
    sdj 8:144 0 1.1T 0 disk
    sdk 8:160 0 1.1T 0 disk
    sdl 8:176 0 1.1T 0 disk
    sdm 8:192 0 1.1T 0 disk
    sdn 8:208 0 1.6T 0 disk
    sdo 8:224 0 1.6T 0 disk
    sdp 8:240 0 1.6T 0 disk
    sdq 65:0 0 1.6T 0 disk
    sdr 65:16 0 1.6T 0 disk
    sds 65:32 0 1.6T 0 disk
    sdt 65:48 0 1.6T 0 disk
    sdu 65:64 0 111.3G 0 disk
    ├─sdu1 65:65 0 1M 0 part
    ├─sdu2 65:66 0 512M 0 part
    ├─sdu3 65:67 0 94.8G 0 part
    └─sdu4 65:68 0 16G 0 part
    on fdisk-l show the disks too
    When create via zpool create and work fine, show just on web Gui Datasets, but on Storage > Disks or Storage Create Pool not working.
    We remove the disks from RAID controler but not work too, dont show on SO
    the configuration on RAID Controle is RAID0
    smartctl -i /dev/sda
    smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
    Vendor: AVAGO
    Product: SMC3108
    Revision: 4.29
    Compliance: SPC-3
    User Capacity: 1,199,705,161,728 bytes [1.19 TB]
    Logical block size: 512 bytes
    Logical Unit id: 0x600304801ab3f3012bf10a0b07be0d8c
    Serial number: 008c0dbe070b0af12b01f3b31a800403
    Device type: disk
    Local Time is: Fri May 12 12:31:53 2023 -03
    SMART support is: Unavailable - device lacks SMART capability.
    Return data and SERIAL too.
    Please let me know if need more some information.
    So we need to help, what we can made for view disk on web gui and work just via web GUI.
jgreco
Resident Grinch
This is not compatible with TrueNAS. You need to remove the RAID controller and replace it with an HBA. ZFS is going to be your RAID controller on this machine. Please see
felipesecure
in TrueNAS Core, work fine and show all devices/disks.
jgreco
Resident Grinch
It doesn't matter why. The device drivers for the two operating systems are a bit different, but regardless, RAID controllers are NOT supported in TrueNAS, and you MUST change out the controller. If you fail to listen to me, you may be back here in a month or two begging about how to get your data back, at which point the data may have been irretrievably lost due to corruption. Do NOT keep using the RAID controller.
felipesecure
SOLVED, i put drivers/controler in JBOD mode and now its work fine.
Your documentation shared halp understand how work.
Tks so much for attention.
jgreco
Resident Grinch
"JBOD mode" is not an acceptable fix. You need to REPLACE the RAID controller with an HBA. Please refer to the article I linked to previously.
felipesecure
But now i can see the raw information disk with "camcontrol devlist", i see on documentation that can generate problem too.
but smartctl same thing, now return this result. so we can have problem using jbod ?
jgreco
Resident Grinch
I don't know if this is a language barrier or issue. I'm going to be blunt here.
The article I gave you is NOT a menu from which you can pick the selections that you find appetizing.
You CANNOT use a RAID controller. Using a RAID controller will lead to problems. Maybe not today, maybe not even tomorrow. We have found NO RAID controllers that have been demonstrated to be safe and reliable.
You MUST hook up your disks to TrueNAS using one of these options:
1) SATA AHCI such as Intel based or AsMedia 106x. The JMicron ("JMB") based ones are unreliable.
2) Intel PCH SCU based SATA or SAS.
3) LSI/Avago/Broadcom HBA in IT mode, based on the 2008, 2308, or 3008 chipsets.
All other options are risky and many people who have plowed ahead anyways have run into catastrophes ranging from data corruption all the way on up to loss of ZFS pool.
felipesecure
Hi Jgreco,
in case of AVAGO SAS 3108 not listed on your item 3)
so we need to change to other HBA for not have problem, correct ?
description: RAID bus controller
product: MegaRAID SAS-3 3108 [Invader]
vendor: Broadcom / LSI
physical id: 0
bus info: pci@0000:02:00.0
logical name: scsi0
version: 02
width: 64 bits
clock: 33MHz
capabilities: raid pm pciexpress vpd msi msix bus_master cap_list rom
configuration: driver=megaraid_sas latency=0
resources: irq:26 ioport:e000(size=256) memory:fb300000-fb30ffff memory:fb200000-fb2fffff memory:fb100000-fb1fffff
felipesecure
felipesecure
Jgrecto, sorry, i found any other topics on forum and see that NOT CAN USE thie 3108 or other RAID Controler
We need to change effective to HBA for avoid loss data in future.
Tks so much for your attention
jgreco
Resident Grinch
Please go read what I've written.
The SAS3108 is a RAID-on-Chip. You got it there straight from Broadcom.
I told you you CANNOT use a RAID controller.
in my reads, we see that 3108 are the next gen of 3008.
Then you are misreading. They are different products for different needs. The 3108 is the successor to the 2208 RAID chipset. The 3008 is the successor to the 2308 HBA chipset. These are very different product lines.
