Encryption Type
wave2453
I am currently looking to store PHI data on one of my volumes. The thing is I know I will have a PCI auditor asking what encryption method is used and prove it. I looked through the user guide for version 11 and can't find any documentation that states something like "AES-256 is used". Is there any documentation or even better a way for me to show an external auditor that these drives are encrypted and with what type of encryption?
m0nkey_
The command geli list should show what drives are encrypted along with the algorithm and crypto used.
I'd recommend filing a bug report so that the specifics of the encryption algorithm used are added to the manual. I'm fairly certain it's AES-XTS.
To show that the disks are encrypted, you can use geli status, which should list all the encrypted partitions.
wave2453
Both of those commands should suffice for what I need. Thank You both for the help with this!
