I figured this was a different kind of question about the encryption so I should create a new post.
I am trying to figure out how the encryption works and how I can prove it works. As I explained in my other post I am looking to put PHI data on my FreeNAS 11.1 U4 system and it will be audited by external auditors.
I am looking to find out how key management is handled and how can i prove that. I am specifically looking for the following
-Where is the data encrypting key stored?
-is the data encrypting key protected with a key encrypting key and if so where is it stored?
-Is there a command, documentation or config file that shows the above to be true?
Thank You!
Thank You!
