How to tell if encryption is turned on
gzunk
Forgive me if I'm asking a stupid question, but I've searched the forums without an answer. I believe I've created my volumes without encryption but in the log files I see the following:
Aug 21 21:33:00 ned kernel: GEOM_ELI: Device da4p1.eli created.
Aug 21 21:33:00 ned kernel: GEOM_ELI: Encryption: AES-XTS 256
Aug 21 21:33:00 ned kernel: GEOM_ELI: Crypto: hardware
Aug 21 21:33:00 ned kernel: GEOM_ELI: Device da3p1.eli created.
Aug 21 21:33:00 ned kernel: GEOM_ELI: Device da2p1.eli created.
etc etc, So is that saying that I am using encrypted volumes or not?
That's for the swap partition.
panz
Swap is always encrypted, even if you didn't choose encryption for the pool. Read the manual, it's all explained there!
