Building a new NAS box w/ FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty), creating a new volume inside the WebUI and watching the log file, when I see this...
So what's up with this? I checked to see what geli thought in the command line:
So I destroyed the volume, and tried to create it again... making sure I didn't click the encryption checkbox this time (just to be sure), and the same thing happens.
Is this a bug? Or something that's expected? Because it seems awfully odd that GELI is telling me there's encryption on these slices when I don't want it.
Aug 1 14:53:13 freenas2 kernel: GEOM_NOP: Device da1p2.nop created.
Aug 1 14:53:13 freenas2 kernel: GEOM_NOP: Device da2p2.nop created.
Aug 1 14:53:13 freenas2 kernel: GEOM_NOP: Device da3p2.nop created.
Aug 1 14:53:13 freenas2 kernel: GEOM_NOP: Device da4p2.nop created.
Aug 1 14:53:14 freenas2 kernel: GEOM_NOP: Device da5p2.nop created.
Aug 1 14:53:14 freenas2 kernel: GEOM_NOP: Device da6p2.nop created.
Aug 1 14:53:14 freenas2 kernel: GEOM_NOP: Device da7p2.nop created.
Aug 1 14:53:14 freenas2 kernel: GEOM_NOP: Device da8p2.nop created.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da1p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da2p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da3p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da4p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da5p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da6p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da7p2.nop removed.
Aug 1 14:53:19 freenas2 kernel: GEOM_NOP: Device da8p2.nop removed.
Aug 1 14:53:45 freenas2 kernel: GEOM_ELI: Device da1p1.eli created.
Aug 1 14:53:45 freenas2 kernel: GEOM_ELI: Encryption: AES-XTS 256
Aug 1 14:53:45 freenas2 kernel: GEOM_ELI: Crypto: software
Aug 1 14:53:45 freenas2 kernel: GEOM_ELI: Device da2p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da3p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Encryption: AES-XTS 256
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Crypto: software
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da4p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da5p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da6p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da7p1.eli created.
Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da8p1.eli created.
Note: I didn't select encryption when creating the volume.... ;)Aug 1 14:53:46 freenas2 kernel: GEOM_ELI: Device da6p1.eli created.
# geli status da8p1.eli
Name Status Components
da8p1.eli ACTIVE da8p1
# geli list da8p1.eli
Geom name: da8p1.eli
State: ACTIVE
EncryptionAlgorithm: AES-XTS
KeyLength: 256
Crypto: software
Flags: ONETIME, W-DETACH, W-OPEN
Providers:
1. Name: da8p1.eli
Mediasize: 2147483648 (2.0G)
Sectorsize: 4096
Mode: r1w1e0
Consumers:
1. Name: da8p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e1
