Enabling hw.ix.allow_unsupported_sfp=1 in Scale
Jeremy MItchell
I'm new to Scale (been using Core since it was FreeNAS v9) and I'm also experimenting with a bit of 10Gbe networking. I've purchased a couple of used Intel X520-DA2 cards that came with Cisco SFP transceivers. I know I need to enable the tunable
to make the cards work with these transceivers.
I currently have an Init/Shutdown script in settings/advanced that runs the commands:
rmmod ixgbe
modprobe ixgbe allow_unsupported_sfp=1
as "command" and "Post init".
This does the job and the interfaces appear in the network settings.
Is this the correct/best way to do this? (Besides going out and buying some Intel transcievers.). I can't seem to find any documentation or forum posts on how to set tunables like this.
I should note that I don't have the cards connected yet, I'm still waiting for the fibre patch cable to arrive. Dunno if that makes a difference.
Thanks.
