Baenwort
- Feb 19, 2015
I have a 11.1 made emby jail running under warden that operates successfully but is so out of date that the Emby apps won't connect due to old server version. There is no update for the Warden plugin so I'm forced to 11.2 as earlier than RC2 has mount issues if you have spaces in your file path.
The script ran successfully and the new iocage jail is able to start. However, when I try to update the release version from 11.0-RELEASE to anything newer I get the following error when performing the update via the GUI.
Networking is functional as I can ping out of the jail and the Emby server web interface is functional. However, unless I can up the release version of FreeBSD I can not update emby due to the EOL of the base FreeBSD version.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 773, in upgrade
IOCUpgrade(conf, release, root_path).upgrade_jail()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_upgrade.py", line 116, in upgrade_jail
raise RuntimeError("Error occured, jail not upgraded!")
RuntimeError: Error occured, jail not upgraded!
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor
