So, Emby deployment really doesn't work for me on Scale.
When I originally installed 4.7.6.0_1.0.11 for the first time, it was stuck on deploying.
I was able to get it to actually work but modifying the deployment.yaml file per below.
www.truenas.com
I tried to use the Upgrade option to 4.7.8.0_1.0.12, but was stuck on deploying.
Tried to you my original fix, but it didn't help. I used the Rollback function and my original version works fine.
I tried to use the Upgrade option to 4.7.9.0_1.0.13, but again it is stuck on deploying.
emby on scale stuck on deploying
the first time i re-installed emby, it worked, but then it stopped after some time and now it gets stuck on deploying. Switching to the log shows the below error. I note when emby starts the first time, it still has 8096 as the port, and even though i have changed this, it still seems to want...
