Ok, I got an update:
After pulling a drive from a RAIDZ2 and leaving the array with no parity overnight I got my daily message. The security run was normal since this wasn't an issue that would reflect on the security log. The daily run had the following:
So now we know. You get a degraded status on the daily run and that's about all.
This output is basically a 'zpool status -v' and nothing more.
Checking status of zfs pools: NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT test 172G 2.28G 170G 1% 1.00x DEGRADED /mnt pool: test state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://www.sun.com/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0h0m with 0 errors on Thu Aug 9 01:34:37 2012 config: NAME STATE READ WRITE CKSUM test DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 6599038171086723991 UNAVAIL 0 0 0 was /dev/da1p2 da0p2 ONLINE 0 0 0 da1p2 ONLINE 0 0 0 errors: No known data errors Checking status of ATA raid partitions: Checking status of gmirror(8) devices: Checking status of graid3(8) devices: Checking status of gstripe(8) devices:
