SOLVED Dual NIC PCI Passthrough - user not reading docs
GastonJ
Having a few issues with PCI passthrough and an Intel dual port NIc.
My server is HP Microserver Gen8
Intel(R) Xeon(R) CPU E31265L @ 2.40GHz
So
root@truenas[~]# lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:06.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation C204 Chipset LPC Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family Desktop SATA Controller (IDE mode, ports 0-3) (rev 05)
00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family Desktop SATA Controller (IDE mode, ports 4-5) (rev 05)
01:00.0 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Slave Instrumentation & System Support (rev 05)
01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH
01:00.2 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Management Processor Support and Messaging (rev 05)
01:00.4 USB controller: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller (rev 02)
03:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe
03:00.1 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe
04:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03)
07:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
07:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
It's teh devices on 07:00:0 and 07:00:1 that I want
root@truenas[~]# dmesg|grep DMAR
[ 0.009550] ACPI: DMAR 0x00000000F1DE4A80 0003F0 (v01 HP ProLiant 00000001 \xd2? 0000162E)
[ 0.009600] ACPI: Reserving DMAR table memory at [mem 0xf1de4a80-0xf1de4e6f]
[ 0.030034] DMAR: IOMMU enabled
[ 0.103989] DMAR: Host address width 39
[ 0.104054] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.104125] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f010da
[ 0.104206] DMAR: RMRR base: 0x000000f1ffd000 end: 0x000000f1ffffff
[ 0.104274] DMAR: RMRR base: 0x000000f1ff6000 end: 0x000000f1ffcfff
[ 0.104341] DMAR: RMRR base: 0x000000f1f93000 end: 0x000000f1f94fff
[ 0.104409] DMAR: RMRR base: 0x000000f1f8f000 end: 0x000000f1f92fff
[ 0.104476] DMAR: RMRR base: 0x000000f1f7f000 end: 0x000000f1f8efff
[ 0.104543] DMAR: RMRR base: 0x000000f1f7e000 end: 0x000000f1f7efff
[ 0.104609] DMAR: RMRR base: 0x000000000f4000 end: 0x000000000f4fff
[ 0.104676] DMAR: RMRR base: 0x000000000e8000 end: 0x000000000e8fff
[ 0.104743] DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x00000000000e8000-0x00000000000e8fff], contact BIOS vendor for fixes
[ 0.104832] DMAR: [Firmware Bug]: Your BIOS is broken; bad RMRR [0x00000000000e8000-0x00000000000e8fff]
[ 0.104932] DMAR: RMRR base: 0x000000f1dee000 end: 0x000000f1deefff
[ 0.105001] DMAR-IR: IOAPIC id 8 under DRHD base 0xfed90000 IOMMU 0
[ 0.105068] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.105136] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.105136] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.105561] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 1.571451] DMAR: No ATSR found
[ 1.571889] DMAR: dmar0: Using Queued invalidation
[ 1.573801] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 2.151025] DMAR: DRHD: handling fault status reg 2
[ 2.151108] DMAR: [INTR-REMAP] Request device [01:00.0] fault index 1e [fault reason 38] Blocked an interrupt request due to source-id verification failure
[ 567.962290] vfio-pci 0000:07:00.0: DMAR: Device is ineligible for IOMMU domain attach due to platform RMRR requirement. Contact your platform vendor.
[ 682.251400] vfio-pci 0000:07:00.0: DMAR: Device is ineligible for IOMMU domain attach due to platform RMRR requirement. Contact your platform vendor.
The last 3 messages are worrying really and may well be the reason.
root@truenas[~]# shopt -s nullglob
for g in $(find /sys/kernel/iommu_groups/* -maxdepth 0 -type d | sort -V); do
echo "IOMMU Group ${g##*/}:"
for d in $g/devices/*; do
echo -e "\t$(lspci -nns ${d##*/})"
done;
done;
zsh: command not found: shopt
IOMMU Group 0:
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 Processor Family DRAM Controller [8086:0108] (rev 09)
IOMMU Group 1:
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port [8086:0101] (rev 09)
07:00.0 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
07:00.1 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
IOMMU Group 2:
00:06.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port [8086:010d] (rev 09)
IOMMU Group 3:
00:1a.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 05)
IOMMU Group 4:
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b5)
IOMMU Group 5:
00:1c.4 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 [8086:1c18] (rev b5)
IOMMU Group 6:
00:1c.6 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 [8086:1c1c] (rev b5)
IOMMU Group 7:
00:1c.7 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 [8086:1c1e] (rev b5)
IOMMU Group 8:
00:1d.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 05)
IOMMU Group 9:
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev a5)
IOMMU Group 10:
00:1f.0 ISA bridge [0601]: Intel Corporation C204 Chipset LPC Controller [8086:1c54] (rev 05)
00:1f.2 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family Desktop SATA Controller (IDE mode, ports 0-3) [8086:1c00] (rev 05)
00:1f.5 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family Desktop SATA Controller (IDE mode, ports 4-5) [8086:1c08] (rev 05)
IOMMU Group 11:
03:00.0 Ethernet controller [0200]: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe [14e4:165f]
03:00.1 Ethernet controller [0200]: Broadcom Inc. and subsidiaries NetXtreme BCM5720 2-port Gigabit Ethernet PCIe [14e4:165f]
IOMMU Group 12:
04:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller [1912:0014] (rev 03)
IOMMU Group 13:
01:00.0 System peripheral [0880]: Hewlett-Packard Company Integrated Lights-Out Standard Slave Instrumentation & System Support [103c:3306] (rev 05)
01:00.1 VGA compatible controller [0300]: Matrox Electronics Systems Ltd. MGA G200EH [102b:0533]
01:00.2 System peripheral [0880]: Hewlett-Packard Company Integrated Lights-Out Standard Management Processor Support and Messaging [103c:3307] (rev 05)
01:00.4 USB controller [0c03]: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller [103c:3300] (rev 02)
and that shows them in IOMMU Group 1:
Devices on the VM
27 and 28 being
27 - pptdev: pci_0000_07_00_0
28 - pptdev: pci_0000_07_00_1
All well and good until I try to start it.
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2022-11-03T15:37:29.486857Z qemu-system-x86_64: -device vfio-pci,host=0000:07:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:07:00.0: failed to setup container for group 1: Failed to set iommu for container: Operation not permitted
Details
Now I'm assuming since its mentioning group 1 that it's referring to
IOMMU Group 1:
I have tried to passthrough
00:01.0
but I get
[EFAULT] internal error: Non-endpoint PCI devices cannot be assigned to guests
Details
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 165, in start if self.domain.create() < 0: File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create raise libvirtError('virDomainCreate() failed') libvirt.libvirtError: internal error: Non-endpoint PCI devices cannot be assigned to guests During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 177, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 39, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1209, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 62, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name)) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 174, in start raise CallError('\n'.join(errors)) middlewared.service_exception.CallError: [EFAULT] internal error: Non-endpoint PCI devices cannot be assigned to guests
So it won't be that which I have to pass through. Or I don't think so anyway.
Have I missed something?
Cheers
morganL
Captain Morgan
Administrator
So
done;
done;
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 2:
IOMMU Group 3:
IOMMU Group 4:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
IOMMU Group 10:
IOMMU Group 11:
IOMMU Group 12:
IOMMU Group 13:
Devices on the VM
27 and 28 being
Details
IOMMU Group 1:
00:01.0
but I get
Details
Cheers
With NICs, we typically assign ports to the VM.... I'm not sure we've passed through whole NICs. Has anyone else tried that?
Is there a reason to pass through the NIC rather than assign the ports?
GastonJ
My main reason for doing it this way is isolation, with the plan to have the VM being my pfsense firewall. I do have another node that runs proxmox, where my firewall currently is, and that's the way I configured that - it used KVM. That's not a HP though. However looking at the HP Microserver, Gen8, it may well be that my issue is around RMRR and the HP hardware.
Since it's unlikely HP will ever release an updated BIOS for something they consider old, then this may not be achievable. So I may have to drop this one and look for a new platform.
Regards
GastonJ
For info it's this
- HPE published advisory recommending connrep disabling RMRR for physical PCI slots but unfortunately while Microserver Gen8 is affected, the method doesn't work for it, and it only applies to 3rd-party devices in a slot and not to e.g. built-in ethernets or P120i
However, the Microserver has 2 onboard NICS. I may swap them around, use the external card as my main card for Truenas and try pass through on teh 2 Internal NICs to see if it allows that.
I'll see how my other half has planned my weekend to allow me any time for my own stuff :smile: and share the results. If it works all good, if it doesn't it will help others.
GastonJ
As a quick test, I attempted to pass through my second onboard ethernet.
The result being
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2022-11-04T12:23:39.942716Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.1,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:03:00.1: group 11 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver.
report_problem CallError
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2022-11-04T12:26:04.967510Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.1,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:03:00.1: group 11 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver.
remove_circle_outlineMore info...
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 165, in start if self.domain.create() < 0: File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create raise libvirtError('virDomainCreate() failed') libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2022-11-04T12:26:04.967510Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.1,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:03:00.1: group 11 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver.
Which I'd sort of expected to happen only passing a single device in that group over.
IOMMU Group 11:
So that's looking promising for passthrough to work on the onboard Ethernet's. I'll pass both over in my next attempt.
Cheers
GastonJ
So swapped them over, and that's a fail using the internal NICS for the VM.
[ 2.162219] DMAR: DRHD: handling fault status reg 2
[ 2.162297] DMAR: [INTR-REMAP] Request device [01:00.0] fault index 1e [fault reason 38] Blocked an interrupt request due to source-id verification failure
[ 159.793726] vfio-pci 0000:03:00.0: DMAR: Device is ineligible for IOMMU domain attach due to platform RMRR requirement. Contact your platform vendor.
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2022-11-04T12:58:54.546466Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:03:00.0: failed to setup container for group 11: Failed to set iommu for container: Operation not permitted
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 165, in start if self.domain.create() < 0: File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create raise libvirtError('virDomainCreate() failed') libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2022-11-04T12:58:54.546466Z qemu-system-x86_64: -device vfio-pci,host=0000:03:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:03:00.0: failed to setup container for group 11: Failed to set iommu for container: Operation not permitted
So I'm out of ideas on this one.
Unless anyone has some pointers on something I've missed? Short of throwing my HP servers into a canal that is.
Cheers
GastonJ
My bad, I just re-reread
morganL's post.​
I hadn't even realised there was an option to pass the NIC's, I had thought it was just passing the PCI device. Trying to pass the NIC rather than the device seems to do the trick.
Thank you
R.Heaton
morganL's post.​
Thank you
Hello. Would you mind sharing how you did this? I have done the ground work, enabling IOMMU, VT-D, etc, downloaded and deployed HP scripting tools and identified what I need to pass through but I just don't know how to add those items to an exclude.dat file (if that is, indeed, the way you ended up doing it.) Any help would be greatly appreciated.
Thank you.
