Jghake
 - Sep 6, 2021
I have a small Lenovo M92p and a 4 bay USB3 drive enclosure with 3 2TB drives. I have a 4th drive that is removed from the system and has my data on it.
I struggled quite a bit to get TrueNAS installed, but slaving the SSD to my laptop, using the CD drive to install it, then swapping the SSD back into the Lenovo and booting up. Only Legacy mode will work, but I am able to get into the web interface for TrueNAS.
When I try to create the pool, I am only presented with options for DA2. egrep 'da[0-9]|cd[0-9]' /var/run/dmesg.boot at the command line shows below:
Does anyone have any insight?
truenas% egrep 'da[0-9]|cd[0-9]' /var/run/dmesg.boot ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 ada0: <PNY CS900 240GB SSD CS900P13> ACS-4 ATA SATA 3.x device ada0: Serial Number PNY21022101050103F8E ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 228936MB (468862128 512 byte sectors) ses0: ada0,pass0 in 'Slot 00', SATA Slot: scbus0 target 0 da0 at umass-sim0 bus 0 scbus3 target 0 lun 0 da0: <ST320006 44NS 0125> Fixed Direct Access SPC-4 SCSI device da0: Serial Number 152D00539000 da0: 400.000MB/s transfers da0: 1907729MB (3907029168 512 byte sectors) da0: quirks=0x2<NO_6_BYTE> da1 at umass-sim0 bus 0 scbus3 target 0 lun 1 da1: <ST320006 44NS 0125> Fixed Direct Access SPC-4 SCSI device da1: Serial Number 152D00539000 da1: 400.000MB/s transfers da1: 1907729MB (3907029168 512 byte sectors) da1: quirks=0x2<NO_6_BYTE> da2 at umass-sim0 bus 0 scbus3 target 0 lun 2 da2: <ST320006 44NS 0125> Fixed Direct Access SPC-4 SCSI device da2: Serial Number 152D00539000 da2: 400.000MB/s transfers da2: 1907729MB (3907029168 512 byte sectors) da2: quirks=0x2<NO_6_BYTE> GEOM_ELI: Device da1p1.eli created.
