Kristoffer Nilsen
- Sep 11, 2015
I have 10 drives in a ZFS pool and everything has been working great for about a year. 9 drives of 2TB and 1 drive of 3TB.
My motherboard died and I had to replace it. Luckly I had a identical motherboard at hand.
It's a motherboard from a HP XW6400. CPU is Intel(R) Xeon(R) CPU 5130 @ 2.00GHz. 8GB DDR2 RAM.
Chipset Type: Intel 5000X
Processor Socket: LGA771
RAM Technology: DDR2 SDRAM / ECC
Memory Speed: 667 MHz
Memory Specification Compliance: PC2-5300
Drives: WD Desktop Green
RAID Cards: 2x LSI 1064E-IR
I had 2 pools. Named pool01 and pool02 (great naming, I know).
When I booted the system up again with the new motherboard I ran the command "zpool import -f"
pool01 cam up with no problems, but the importent, large pool02 did not. I have used the last two days trying to reinstall OS, change position of the drives (changing up the sata-connections etc). But i'm finding no luck.
It looks like one drive are missing from pool02, but the drive is connected and I don't see any error.
I'm about to give up now, but I really hope there are someone out there who can help me.
Here are som data:
FreeNAS-9.3-STABLE-201506292332
I would really appreciate if anyone can give me some help, if possible.
Here are som data:
[root@nas2] ~# zpool import -f pool: pool02 id: 7346222624618935135 state: UNAVAIL status: The pool was last accessed by another system. action: The pool cannot be imported due to damaged devices or data. see: http://illumos.org/msg/ZFS-8000-EY config: pool02 UNAVAIL missing device raidz1-1 ONLINE gptid/f42669d6-bbae-11e4-a886-001cc41ff072 ONLINE gptid/f58467d3-bbae-11e4-a886-001cc41ff072 ONLINE gptid/f673a2ac-bbae-11e4-a886-001cc41ff072 ONLINE gptid/f72d88e7-bbae-11e4-a886-001cc41ff072 ONLINE gptid/f8364ceb-bbae-11e4-a886-001cc41ff072 ONLINE gptid/f9616ed7-bbae-11e4-a886-001cc41ff072 ONLINE gptid/fae1348e-bbae-11e4-a886-001cc41ff072 ONLINE gptid/fc1a58c0-bbae-11e4-a886-001cc41ff072 ONLINE gptid/fd068f4b-bbae-11e4-a886-001cc41ff072 ONLINE
[root@nas2] ~# camcontrol devlist <ATA ST33000651AS CC43> at scbus0 target 1 lun 0 (pass0,da0) <ATA ST2000DM001-9YN1 CC4B> at scbus0 target 2 lun 0 (pass1,da1) <ATA WDC WD20EARX-55P AB51> at scbus0 target 3 lun 0 (pass2,da2) <ATA WDC WD20EARX-00P AB51> at scbus2 target 1 lun 0 (pass3,da3) <ATA WDC WD20EARX-00P AB51> at scbus2 target 2 lun 0 (pass4,da4) <ATA WDC WD20EARX-00P AB51> at scbus2 target 3 lun 0 (pass5,da5) <ST2000DL003-9VT166 CC98> at scbus5 target 0 lun 0 (pass6,ada0) <WDC WD20EARX-00PASB0 51.0AB51> at scbus6 target 0 lun 0 (pass7,ada1) <WDC WD20EARS-00MVWB0 51.0AB51> at scbus7 target 0 lun 0 (pass8,ada2) <WDC WD20EARX-00PASB0 51.0AB51> at scbus8 target 0 lun 0 (pass9,ada3) <Verbatim STORE N GO 1100> at scbus12 target 0 lun 0 (pass10,da6)
[root@nas2] /# dmesg The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.3-RELEASE-p16 #1 r281084+74d0d7a: Mon Jun 29 14:32:16 PDT 2015 root@build3.ixsystems.com:/tank/home/jkh/build/FN/objs/os-base/amd64/tank/home/jkh/build/FN/FreeBSD/src/sys/FREENAS.amd64 amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: Intel(R) Xeon(R) CPU 5130 @ 2.00GHz (1995.04-MHz K8-class CPU) Origin = "GenuineIntel" Id = 0x6f6 Family = 0x6 Model = 0xf Stepping = 6 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Features2=0x4e33d<SSE3,DTES64,MON,DS_CPL,VMX,TM2,SSSE3,CX16,xTPR,PDCM,DCA> AMD Features=0x20100800<SYSCALL,NX,LM> AMD Features2=0x1<LAHF> TSC: P-state invariant, performance statistics real memory = 9395240960 (8960 MB) avail memory = 8230187008 (7848 MB) Event timer "LAPIC" quality 400 ACPI APIC Table: <COMPAQ GREENCRK> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs FreeBSD/SMP: 1 package(s) x 2 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ACPI Error: 32/64X address mismatch in Gpe0Block: 0x0000F828/0x000000000001F030, using 32 (20111123/tbfadt-470) ioapic0 <Version 2.0> irqs 0-23 on motherboard ispfw: registered firmware <isp_1040> ispfw: registered firmware <isp_1040_it> ispfw: registered firmware <isp_1080> ispfw: registered firmware <isp_1080_it> ispfw: registered firmware <isp_12160> ispfw: registered firmware <isp_12160_it> ispfw: registered firmware <isp_2100> ispfw: registered firmware <isp_2200> ispfw: registered firmware <isp_2300> ispfw: registered firmware <isp_2322> ispfw: registered firmware <isp_2400> ispfw: registered firmware <isp_2400_multi> ispfw: registered firmware <isp_2500> ispfw: registered firmware <isp_2500_multi> kbd1 at kbdmux0 cryptosoft0: <software crypto> on motherboard aesni0: No AESNI support. padlock0: No ACE support. acpi0: <HPQOEM SLIC-WKS> on motherboard acpi0: Power Button (fixed) acpi0: reservation of 0, a0000 (3) failed acpi0: reservation of 100000, cff00000 (3) failed cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 Event timer "RTC" frequency 32768 Hz quality 0 hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Event timer "HPET" frequency 14318180 Hz quality 450 Event timer "HPET1" frequency 14318180 Hz quality 440 Event timer "HPET2" frequency 14318180 Hz quality 440 Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 acpi_timer0: <24-bit timer at 3.579545MHz> port 0xf808-0xf80b on acpi0 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 device_attach: hpet0 attach returned 12 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 pcib1: <ACPI PCI-PCI bridge> at device 2.0 on pci0 pci16: <ACPI PCI bus> on pcib1 pcib2: <ACPI PCI-PCI bridge> at device 0.0 on pci16 pci30: <ACPI PCI bus> on pcib2 pcib3: <ACPI PCI-PCI bridge> at device 0.0 on pci30 pci32: <ACPI PCI bus> on pcib3 pcib4: <ACPI PCI-PCI bridge> at device 1.0 on pci30 pci31: <ACPI PCI bus> on pcib4 bge0: <Broadcom NetXtreme Gigabit Ethernet Controller, ASIC rev. 0x006001> mem 0xf2200000-0xf220ffff irq 17 at device 0.0 on pci31 bge0: CHIP ID 0x00006001; ASIC REV 0x06; CHIP REV 0x60; PCI-E miibus0: <MII bus> on bge0 brgphy0: <BCM5752 1000BASE-T media interface> PHY 1 on miibus0 brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow bge0: Ethernet address: 00:1c:c4:1f:f0:72 pcib5: <PCI-PCI bridge> mem 0xf2301000-0xf2301fff at device 0.3 on pci16 pci17: <PCI bus> on pcib5 pcib6: <ACPI PCI-PCI bridge> at device 3.0 on pci0 pci96: <ACPI PCI bus> on pcib6 mpt0: <LSILogic SAS/SATA Adapter> port 0x2000-0x20ff mem 0xf2110000-0xf2113fff,0xf2100000-0xf210ffff irq 16 at device 0.0 on pci96 mpt0: MPI Version=1.5.12.0 mpt0: Capabilities: ( RAID-0 RAID-1E RAID-1 ) mpt0: 0 Active Volumes (2 Max) mpt0: 0 Hidden Drive Members (10 Max) pcib7: <ACPI PCI-PCI bridge> at device 4.0 on pci0 pci64: <ACPI PCI bus> on pcib7 vgapci0: <VGA-compatible display> port 0x3000-0x307f mem 0xf0000000-0xf0ffffff,0xd0000000-0xdfffffff,0xf1000000-0xf1ffffff irq 16 at device 0.0 on pci64 vgapci0: Boot video device pcib8: <PCI-PCI bridge> at device 5.0 on pci0 pci254: <PCI bus> on pcib8 pcib9: <PCI-PCI bridge> at device 6.0 on pci0 pci253: <PCI bus> on pcib9 pcib10: <PCI-PCI bridge> at device 7.0 on pci0 pci252: <PCI bus> on pcib10 pcib11: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0 pci128: <ACPI PCI bus> on pcib11 mpt1: <LSILogic SAS/SATA Adapter> port 0x1000-0x10ff mem 0xf2010000-0xf2013fff,0xf2000000-0xf200ffff irq 16 at device 0.0 on pci128 mpt1: MPI Version=1.5.12.0 mpt1: Capabilities: ( RAID-0 RAID-1E RAID-1 ) mpt1: 0 Active Volumes (2 Max) mpt1: 0 Hidden Drive Members (10 Max) uhci0: <Intel 631XESB/632XESB/3100 USB controller USB-1> port 0x4000-0x401f irq 16 at device 29.0 on pci0 usbus0 on uhci0 uhci1: <Intel 631XESB/632XESB/3100 USB controller USB-2> port 0x4020-0x403f irq 19 at device 29.1 on pci0 usbus1 on uhci1 uhci2: <Intel 631XESB/632XESB/3100 USB controller USB-3> port 0x4040-0x405f irq 18 at device 29.2 on pci0 usbus2 on uhci2 uhci3: <Intel 631XESB/632XESB/3100 USB controller USB-4> port 0x4060-0x407f irq 23 at device 29.3 on pci0 usbus3 on uhci3 ehci0: <Intel 63XXESB USB 2.0 controller> mem 0xf2400000-0xf24003ff irq 16 at device 29.7 on pci0 usbus4: EHCI version 1.0 usbus4 on ehci0 pcib12: <ACPI PCI-PCI bridge> at device 30.0 on pci0 pci1: <ACPI PCI bus> on pcib12 isab0: <PCI-ISA bridge> at device 31.0 on pci0 isa0: <ISA bus> on isab0 atapci0: <Intel 63XXESB2 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x40c0-0x40cf irq 17 at device 31.1 on pci0 ata0: <ATA channel> at channel 0 on atapci0 ahci0: <Intel ESB2 AHCI SATA controller> port 0x40e0-0x40e7,0x40f8-0x40fb,0x40e8-0x40ef,0x40fc-0x40ff,0x4080-0x409f mem 0xf2400400-0xf24007ff irq 19 at device 31.2 on pci0 ahci0: AHCI v1.10 with 6 3Gbps ports, Port Multiplier not supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich2: <AHCI channel> at channel 2 on ahci0 ahcich3: <AHCI channel> at channel 3 on ahci0 ahcich4: <AHCI channel> at channel 4 on ahci0 ahcich5: <AHCI channel> at channel 5 on ahci0 acpi_button0: <Power Button> on acpi0 atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0 ichwd0 on isa0 ichwd0: resuming after hardware watchdog timeout sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 coretemp0: <CPU On-Die Thermal Sensors> on cpu0 coretemp1: <CPU On-Die Thermal Sensors> on cpu1 ZFS filesystem version: 5 ZFS storage pool version: features support (5000) Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled usbus0: 12Mbps Full Speed USB v1.0 usbus1: 12Mbps Full Speed USB v1.0 usbus2: 12Mbps Full Speed USB v1.0 usbus3: 12Mbps Full Speed USB v1.0 usbus4: 480Mbps High Speed USB v2.0 ugen0.1: <Intel> at usbus0 uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 ugen1.1: <Intel> at usbus1 uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1 ugen2.1: <Intel> at usbus2 uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2 ugen3.1: <Intel> at usbus3 uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3 ugen4.1: <Intel> at usbus4 uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4 uhub0: 2 ports with 2 removable, self powered uhub1: 2 ports with 2 removable, self powered uhub2: 2 ports with 2 removable, self powered uhub3: 2 ports with 2 removable, self powered uhub4: 8 ports with 8 removable, self powered ugen4.2: <Verbatim> at usbus4 umass0: <Verbatim STORE N GO, class 0/0, rev 2.10/11.00, addr 2> on usbus4 umass0: SCSI over Bulk-Only; quirks = 0x8100 umass0:12:0:-1: Attached to scbus12 da0 at mpt0 bus 0 scbus0 target 1 lun 0 da0: <ATA ST33000651AS CC43> Fixed Direct Access SCSI-5 device da0: Serial Number 9XK0C20Y da0: 300.000MB/s transfers da0: Command Queueing enabled da0: 2097151MB (4294967295 512 byte sectors: 255H 63S/T 267349C) da1 at mpt0 bus 0 scbus0 target 2 lun 0 da1: <ATA ST2000DM001-9YN1 CC4B> Fixed Direct Access SCSI-5 device da1: Serial Number Z1F17L7V da1: 300.000MB/s transfers da1: Command Queueing enabled da1: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C) da1: quirks=0x8<4K> da2 at mpt0 bus 0 scbus0 target 3 lun 0 da2: <ATA WDC WD20EARX-55P AB51> Fixed Direct Access SCSI-5 device da2: Serial Number WD-WCAZAJ286546 da2: 300.000MB/s transfers da2: Command Queueing enabled da2: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C) da2: quirks=0x8<4K> da3 at mpt1 bus 0 scbus2 target 1 lun 0 da3: <ATA WDC WD20EARX-00P AB51> Fixed Direct Access SCSI-5 device da3: Serial Number WD-WCAZA9730138 da3: 300.000MB/s transfers da3: Command Queueing enabled da3: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C) da3: quirks=0x8<4K> da4 at mpt1 bus 0 scbus2 target 2 lun 0 da4: <ATA WDC WD20EARX-00P AB51> Fixed Direct Access SCSI-5 device da4: Serial Number WD-WCAZA9556853 da4: 300.000MB/s transfers da4: Command Queueing enabled da4: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C) da4: quirks=0x8<4K> ada0 at ahcich0 bus 0 scbus5 target 0 lun 0 da5 at mpt1 bus 0 scbus2 target 3 lun 0 da5: <ATA WDC WD20EARX-00P AB51> Fixed Direct Access SCSI-5 device da5: Serial Number WD-WCAZAC299396 da5: 300.000MB/s transfers da5: Command Queueing enabled da5: 1907729MB (3907029168 512 byte sectors: 255H 63S/T 243201C) da5: quirks=0x8<4K> da6 at umass-sim0 bus 0 scbus12 target 0 lun 0 da6: <Verbatim STORE N GO 1100> Removable Direct Access SCSI-6 device da6: Serial Number 1208000000000001 da6: 40.000MB/s transfers da6: 15376MB (31490048 512 byte sectors: 255H 63S/T 1960C) da6: quirks=0x2<NO_6_BYTE> ada0: <ST2000DL003-9VT166 CC98> ATA-8 SATA 2.x device ada0: Serial Number 5YD8X6HL ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada0: quirks=0x1<4K> ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus6 target 0 lun 0 ada1: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device ada1: Serial Number WD-WCAZAL013711 ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada1: quirks=0x1<4K> ada1: Previously was known as ad6 ada2 at ahcich2 bus 0 scbus7 target 0 lun 0 ada2: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device ada2: Serial Number WD-WCAZA1234395 ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada2: quirks=0x1<4K> ada2: Previously was known as ad8 ada3 at ahcich3 bus 0 scbus8 target 0 lun 0 ada3: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device ada3: Serial Number WD-WCAZAF232373 ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada3: quirks=0x1<4K> ada3: Previously was known as ad10 SMP: AP CPU #1 Launched! Timecounter "TSC" frequency 1995040806 Hz quality 1000 GEOM: da0: corrupt or invalid GPT detected. GEOM: da0: GPT rejected -- may not be recoverable. Trying to mount root from zfs:freenas-boot/ROOT/default []... GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 device_attach: hpet0 attach returned 12 driver bug: Unable to set devclass (devname: (null)) vboxdrv: fAsync=0 offMin=0x3ba offMax=0xc96
