Drives fail smart self test. Pass short smart test.
zlittell
I have 4x WD RED 3TB drives in a MediaSonic ProBox enclosure. These all run eSATA into an esata card in the pcix slot of a dl380 G5 running 9.2.2.1 off of a usb stick. I get email alerts and errors in the console stating that ada2 and ada3 have failed the smart self test. These drives are just opened out of the box as replacements for DOAs. Granted I could have two more bad drives, but is my luck really this bad. When I run a short test it comes back with nothing. SMART still passes it isn't set to failed, they just fail the self test on the 30minute smartd daemon.
It might just be me but it seems like if I have 0 plugins installed these errors never occur, once I install a plugin the error starts occuring. This could be completely in my head though.
What could cause this? Also I still have TLER enabled on the drives can this be a cause of this issue.
Edit:
One thing to note is the two with no issue are from when re4 first released. Could this be an idle park time issue. Surely that wouldn't cause the self check to fail would it?
Yatti420
Could be head parking.. The drives could be truly dying.. Do you test them before putting them in?
zlittell
This is a brand new build. You could even consider it a test build since it will probably be wiped and rebuilt from scratch before going "production". So all testing is really occuring now. Should I just do an extended test on these things. Is that the best way to test them?
Testing is like religion, everyone has their own requirements. When I test a new disk I do:
1. Short SMART test
2. Long SMART test
3. badblocks test with random data
4. Short SMART test
5. Long SMART test
Others do FAR FAR more, but I find this has been good enough for "me'.
zlittell
I will run a couple long tests on each drive when I get home. I already ran 2 or 3 short tests the other day all passing.
zlittell
Alright lots of output to give you guys here:
ADA2 output after extended test:
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:    Western Digital Red (AF)
Device Model:    WDC WD30EFRX-68AX9N0
Serial Number:    WD-WCC1T0886065
LU WWN Device Id: 5 0014ee 25dc04394
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:    512 bytes logical, 4096 bytes physical
ATA Version is:  ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Feb 25 18:35:29 2014 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      (  0) The previous self-test routine completed
                                        been run.
data collection:                (38460) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (  2) minutes.
Extended self-test routine
recommended polling time:        ( 386) minutes.
Conveyance self-test routine
recommended polling time:        (  5) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x002f  100  253  051    Pre-fail  Always      -      0
  3 Spin_Up_Time            0x0027  180  180  021    Pre-fail  Always      -      5991
  4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      49
  5 Reallocated_Sector_Ct  0x0033  200  200  140    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x002e  200  200  000    Old_age  Always      -      0
  9 Power_On_Hours          0x0032  100  100  000    Old_age  Always      -      263
10 Spin_Retry_Count        0x0032  100  253  000    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  100  253  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      29
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      24
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      24
194 Temperature_Celsius    0x0022  118  114  000    Old_age  Always      -      32
196 Reallocated_Event_Count 0x0032  200  200  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0032  200  200  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0030  100  253  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0032  200  200  000    Old_age  Always      -      0
200 Multi_Zone_Error_Rate  0x0008  200  200  000    Old_age  Offline      -      0
SMART Error Log Version: 1
No Errors Logged
# 1  Conveyance offline  Completed without error      00%      256        -
# 2  Conveyance offline  Completed without error      00%      256        -
# 3  Short offline      Completed without error      00%      255        -
# 4  Short offline      Completed without error      00%      255        -
# 5  Extended offline    Completed without error      00%      252        -
# 6  Conveyance offline  Completed without error      00%      242        -
# 7  Short offline      Completed without error      00%      240        -
# 8  Extended offline    Aborted by host              90%      240        -
zlittell
ADA3 output after extended test:
Device Model:    WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N1459780
LU WWN Device Id: 5 0014ee 60418d132
Rotation Rate:    5400 rpm
Local Time is:    Tue Feb 25 18:37:50 2014 CST
Error SMART Status command failed
Please get assistance from
http://smartmontools.sourceforge.net/
Register values returned from SMART Status command are:
CMD=0xb0
FR =0xda
NS =0xffff
SC =0xff
CL =0xff
CH =0xff
RETURN =0x0000
SMART overall-health self-assessment test result: FAILED!
No failed Attributes found.
                                        was never started.
                                        been run.
data collection:                (41520) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 417) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
  3 Spin_Up_Time            0x0027  177  177  021    Pre-fail  Always      -      6108
  4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      11
  9 Power_On_Hours          0x0032  100  100  000    Old_age  Always      -      64
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      7
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      4
193 Load_Cycle_Count        0x0032  200  200  000    Old_age  Always      -      16
No Errors Logged
# 1  Conveyance offline  Completed without error      00%        57        -
# 2  Conveyance offline  Completed without error      00%        57        -
# 3  Short offline      Completed without error      00%        56        -
# 4  Short offline      Completed without error      00%        55        -
# 5  Extended offline    Completed without error      00%        53        -
# 6  Conveyance offline  Completed without error      00%        42        -
zlittell
I have attached the file that contains console messages from the day it ran while these tests were running.
I find it strange that it only is popping on ada3. It started fine. I installed a plugin and it gave the message about ada2. I reformatted the usb stick and tried again. The entire setup time it didn't make a peep installed a plugin and it complained about both ada2 and ada3. Now I reformatted the usb stick again and setup everything, again with no issue then installed LOTS of plugins and it complained about both ada2 and ada3 and now just ada3. Hmmmmmm
  • Console debug messages.txt
Yatti420
Run something else.. Not within FreeNAS.. I keep Hiren's on USB for aiding in issues like these.. Check bios settings etc..
zlittell
I think I am going to go ahead and remove the drives from the enclosure and put them in a old pc. This will allow me to test the drives. I received temporary drive offline alerts at 7pm the other night which is when I was getting outputs to post here. I now am reading online about people not liking esata pm setups. I am thinking this maybe a card issue. Since there was originally no intention of using freenas no compatibility testing was done. I am wondering if I can somehow use the 200i card with a really long sff breakout cable.
zlittell
thinking of going this route:
LSI SAS 3801E
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118076
into a small pc box or rackmount chassis filled with the drives (no mb cpu etc just drives and psu) with this in the back:
koutech io-sff480 4port sas/sata 6G to external sff-8088 mini-sas
http://www.newegg.com/Product/Product.aspx?Item=N82E16816104028
eliminate cheap esata card and port multiplier box and replace with this should solve my issues. I will run tests on the drives just to make sure. I just find it strange that while working on the machine every drive went inaccessible and came back without me noticing and only indication was lots of email alerts.
has anyone used the lsi sas 3801e it was recommended as a top card for opensolaris with zfs build.
at first I was going to get the ibm serveraid m1015 and cross flash it but then I would have to get the internal sff to the other enclosure with either a cable snaked out the back or another PCI slot convertor. I may still go this route just for the fact that it is a proven card with freenas and they are both roughly the same price.
