Hi there,
Auto spin down drives seems not to work. I have configured my disks to spin down after 5 minutes, maximum power saving, no noise.
However if I look in the parameters APM enabled ist still set to no:
Seems, the configuration is not sent to the drives.
[root@freenas] /# ataidle ada1 Model: WDC WD3200BEKT-00F3T0 Serial: WD-WXM********* Firmware Rev: 11.01A11 ATA revision: ATA-8 LBA 48: yes Geometry: 16383 cyls, 16 heads, 63 spt Capacity: 298GB SMART Supported: yes SMART Enabled: yes Write Cache Supported: yes Write Cache Enabled: yes APM Supported: yes APM Enabled: no AAM Supported: yes AAM Enabled: no Vendor Recommended AAM: 1
