Neomancer
- Sep 6, 2014
I have recently setup my first FreeNAS server, and I am very happy with it.
I am having an issue with my storage however. After setting up the system I began getting SMART errors for one of my 3TB drives. It was under warranty so I received a replacement from WD and installed it, replacing the failed drive using the GUI replace. (The drive is a WD Green, not ideal I know but one of those was working in this pool before. The other drive is a WD Red.)
It adds the drive and begins resilvering, but after about 4 hours I get an error that the drive has been removed. Strangely it keeps resilvering after this, (at least according to zpool status) and eventually completes. It has done this a couple of times. The current output of zpool status is below:
If I attempt to online the drive I get the error below:
If I reboot the server it detects the drive and begins resilvering again.
I was hoping someone might have an idea as to what is going on. I have all the data in this pool backed up elsewhere, and the pool is still functioning, so if the answer is rebuilt the pool from scratch so be it, but if there is something I am missing I'd appreciate any help you can offer.
~]$ zpool status Media
pool: Media
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: resilvered 595G in 6h57m with 0 errors on Wed Sep 3 02:43:37 2014
NAME STATE READ WRITE CKSUM
Media DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
gptid/03ee7825-2bcc-11e4-998f-001b214d4deb ONLINE 0 0 0
4950834998254464550 REMOVED 0 0 0 was /dev/gptid/d01d7092-3182-11e4-86ab-001b214d4deb
errors: No known data errors
~]$ zpool online Media /dev/gptid/d01d7092-3182-11e4-86ab-001b214d 4deb cannot online /dev/gptid/d01d7092-3182-11e4-86ab-001b214d4deb: permission denied
