Drive passes extended test in Win10 but is Red Alert in Freenas
Cephyid
Hey, I'm slowly getting things setup but have run into problems that I don't know how to solve. Here's what I've done so far. Specs first.
TS 140 with 20GB of ECC memory and Xeon E3-1225, FreeNAS-9.3-STABLE-201511280648 (just updated).
1. I've successfully got 2x5TB Toshiba drives setup in a stripe, CIFS shares, and data transferred over the network from my PC.
2. I tried importing data directly from disk but that didn't work. I posted in this thread if anyone can figure that problem out.
https://forums.freenas.org/index.php?threads/unable-to-import-ntfs-disks.39665/
3. My next step is to setup a mirror with 2x2TB WD drives. They're greens so I've set wdidle3 to 300 and I've used the WD Data Lifeguard Diagnostics in Windows to run a short and extended test. Everything checks out fine. I've had them for a few years, no problems. There's data on them now but I want to format them and get them online in Freenas fresh.
However when I put them in the server one of them sets off the "red alert".
At this point I'm not sure what my next step is. Those pending sectors are of concern. How do I fix them? Why does the drive show up fine in Windows after an extended test but upon boot without any tests it's flagged in Freenas?
All help is appreciated.
Cephyid
Code from the GUI, green text at the bottom:
Dec  8 17:29:13 freenas ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Dec  8 17:29:13 freenas ada0: da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
Dec  8 17:29:13 freenas da0: <Kingston DataTraveler G3 PMAP> Removable Direct Access SCSI-0 device
Dec  8 17:29:13 freenas da0: Serial Number 001D0F0CCF5CBA70431606FA
Dec  8 17:29:13 freenas da0: 40.000MB/s transfers
Dec  8 17:29:13 freenas da0: 7628MB (15622144 512 byte sectors: 255H 63S/T 972C)
Dec  8 17:29:13 freenas da0: quirks=0x2<NO_6_BYTE>
Dec  8 17:29:13 freenas syslog-ng[1684]: Error processing log message: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device
Dec  8 17:29:13 freenas ada0: Serial Number WD-WMAZA2737311
Dec  8 17:29:13 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec  8 17:29:13 freenas ada0: Command Queueing enabled
Dec  8 17:29:13 freenas ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:29:13 freenas ada0: quirks=0x1<4K>
Dec  8 17:29:13 freenas ada0: Previously was known as ad4
Dec  8 17:29:13 freenas ada1 at ahcich2 bus 0 scbus1 target 0 lun 0
Dec  8 17:29:13 freenas ada1: <TOSHIBA MD04ACA500 FP2A> ATA-8 SATA 3.x device
Dec  8 17:29:13 freenas ada1: Serial Number 85OCK0G5FS9A
Dec  8 17:29:13 freenas ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec  8 17:29:13 freenas ada1: Command Queueing enabled
Dec  8 17:29:13 freenas ada1: 4769307MB (9767541168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:29:13 freenas ada1: Previously was known as ad6
Dec  8 17:29:13 freenas ada2 at ahcich4 bus 0 scbus2 target 0 lun 0
Dec  8 17:29:13 freenas ada2: <TOSHIBA MD04ACA500 FP2A> ATA-8 SATA 3.x device
Dec  8 17:29:13 freenas ada2: Serial Number 9542KDLPFS9A
Dec  8 17:29:13 freenas ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec  8 17:29:13 freenas ada2: Command Queueing enabled
Dec  8 17:29:13 freenas ada2: 4769307MB (9767541168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:29:13 freenas ada2: Previously was known as ad8
Dec  8 17:29:13 freenas SMP: AP CPU #1 Launched!
Dec  8 17:29:13 freenas SMP: AP CPU #2 Launched!
Dec  8 17:29:13 freenas SMP: AP CPU #3 Launched!
Dec  8 17:29:13 freenas Timecounter "TSC-low" frequency 1596339780 Hz quality 1000
Dec  8 17:29:13 freenas Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648 []...
Dec  8 17:29:13 freenas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
Dec  8 17:29:13 freenas wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
Dec  8 17:29:13 freenas root: /etc/rc: WARNING: failed to start watchdogd
Dec  8 17:29:14 freenas GEOM_ELI: Device ada2p1.eli created.
Dec  8 17:29:14 freenas GEOM_ELI: Encryption: AES-XTS 256
Dec  8 17:29:14 freenas GEOM_ELI:     Crypto: hardware
Dec  8 17:29:14 freenas GEOM_ELI: Device ada1p1.eli created.
Dec  8 17:29:15 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Dec  8 17:29:15 freenas vboxdrv: fAsync=0 offMin=0x2b7 offMax=0xe8f
Dec  8 17:29:18 freenas ntpd[2069]: ntpd 4.2.4p5-a (1)
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/net -d 0 getlocalsid
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: zfs list -H -o mountpoint
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmpukbRbh -s /usr/local/etc/smb4.conf -e tdbsam:/var/db/samba4/private/passdb.tdb
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/smbpasswd -e 'daniel'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/smbpasswd -e 'eliana'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/smbpasswd -e 'root'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/bin/getent passwd 'eliana'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/bin/getent passwd 'daniel'
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/pdbedit -d 0 -L
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/net -d 0 sam rights grant root SeTakeOwnershipPrivilege SeBackupPrivilege SeRestorePrivilege
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/net -d 0 sam rights grant daniel SeTakeOwnershipPrivilege SeBackupPrivilege SeRestorePrivilege
Dec  8 17:29:23 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/net -d 0 sam rights grant eliana SeTakeOwnershipPrivilege SeBackupPrivilege SeRestorePrivilege
Dec  8 17:29:24 freenas nmbd[2348]: [2015/12/08 17:29:24.286142,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:29:24 freenas winbindd[2354]: [2015/12/08 17:29:24.375605,  0] ../source3/winbindd/winbindd_cache.c:3196(initialize_winbindd_cache)
Dec  8 17:29:24 freenas winbindd[2354]:   initialize_winbindd_cache: clearing cache and re-creating with version number 2
Dec  8 17:29:24 freenas winbindd[2354]: [2015/12/08 17:29:24.380907,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:29:24 freenas smbd[2351]: [2015/12/08 17:29:24.441186,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:29:24 freenas smbd[2351]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:29:25 freenas smbd[2351]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:29:25 freenas smartd[2357]: Device: /dev/ada0, 33 Currently unreadable (pending) sectors
Dec  8 17:29:26 freenas smartd[2357]: Device: /dev/ada0, 12 Offline uncorrectable sectors
Dec  8 17:29:26 freenas smbd[2351]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec  8 17:29:27 freenas smbd[2351]: dnssd_clientstub ConnectToServer: connect() failed Socket:32 Err:-1 Errno:2 No such file or directory
Dec  8 17:29:47 freenas nmbd[2348]:   STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
Dec  8 17:29:47 freenas nmbd[2348]:   Samba name server FREENAS is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.12
Dec  8 17:29:48 freenas syslog-ng[7366]: syslog-ng starting up; version='3.5.6'
Dec  8 17:29:48 freenas kernel: pid 1684 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Dec  8 17:30:11 freenas ntpd[2070]: time reset -1.160272 s
Dec  8 17:33:27 freenas smbd[7674]:   STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.0.14 != (NULL)
Dec  8 17:33:27 freenas smbd[7674]: [2015/12/08 17:33:27.648153,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Dec  8 17:33:27 freenas smbd[7674]:   matchname failed on 192.168.0.14
Dec  8 17:35:08 freenas notifier: shutdown: [pid 7767]
Dec  8 17:35:08 freenas notifier: Shutdown NOW!
Dec  8 17:35:08 freenas shutdown: reboot by root:
Dec  8 17:35:10 freenas notifier: Shutdown NOW!
Dec  8 17:35:10 freenas notifier: System shutdown time has arrived^G^G
Dec  8 17:35:11 freenas smbd[2351]: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function
Dec  8 17:35:11 freenas winbindd[2354]:   STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=1)
Dec  8 17:35:12 freenas syslog-ng[8061]: syslog-ng starting up; version='3.5.6'
Dec  8 17:35:12 freenas kernel: pid 7366 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Dec  8 17:35:13 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:35:14 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:35:15 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec  8 17:35:16 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:7 Err:-1 Errno:61 Connection refused
Dec  8 17:35:16 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused
Dec  8 17:35:16 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:8 Err:-1 Errno:61 Connection refused
Dec  8 17:35:18 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:35:19 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:35:20 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec  8 17:35:21 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused
Dec  8 17:35:21 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:7 Err:-1 Errno:61 Connection refused
Dec  8 17:35:21 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:8 Err:-1 Errno:61 Connection refused
Dec  8 17:35:22 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:35:23 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:35:24 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec  8 17:35:25 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused
Dec  8 17:35:25 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:7 Err:-1 Errno:61 Connection refused
Dec  8 17:35:25 freenas python: dnssd_clientstub ConnectToServer: connect() failed Socket:8 Err:-1 Errno:61 Connection refused
Dec  8 17:35:27 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:35:28 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:35:29 freenas syslog-ng[8061]: syslog-ng shutting down; version='3.5.6'
Dec  8 17:37:10 freenas syslog-ng[1682]: syslog-ng starting up; version='3.5.6'
Dec  8 17:37:10 freenas Waiting (max 60 seconds) for system process `vnlru' to stop...done
Dec  8 17:37:10 freenas Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Dec  8 17:37:10 freenas Waiting (max 60 seconds) for system process `syncer' to stop...
Dec  8 17:37:10 freenas Syncing disks, vnodes remaining...0 0 0 0 done
Dec  8 17:37:10 freenas All buffers synced.
Dec  8 17:37:10 freenas Copyright (c) 1992-2014 The FreeBSD Project.
Dec  8 17:37:10 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Dec  8 17:37:10 freenas     The Regents of the University of California. All rights reserved.
Dec  8 17:37:10 freenas FreeBSD is a registered trademark of The FreeBSD Foundation.
Dec  8 17:37:10 freenas FreeBSD 9.3-RELEASE-p28 #0 r288272+4d913dc: Fri Nov 27 22:56:01 PST 2015
Dec  8 17:37:10 freenas root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
Dec  8 17:37:10 freenas gcc version 4.2.1 20070831 patched [FreeBSD]
Dec  8 17:37:10 freenas CPU: Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz (3192.68-MHz K8-class CPU)
Dec  8 17:37:10 freenas Origin = "GenuineIntel"  Id = 0x306c3  Family = 0x6  Model = 0x3c  Stepping = 3
Dec  8 17:37:10 freenas Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Dec  8 17:37:10 freenas Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
Dec  8 17:37:10 freenas AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
Dec  8 17:37:10 freenas AMD Features2=0x21<LAHF,ABM>
Dec  8 17:37:10 freenas Standard Extended Features=0x27ab<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
Dec  8 17:37:10 freenas TSC: P-state invariant, performance statistics
Dec  8 17:37:10 freenas real memory  = 21992833024 (20974 MB)
Dec  8 17:37:10 freenas avail memory = 20468346880 (19520 MB)
Dec  8 17:37:10 freenas Event timer "LAPIC" quality 600
Dec  8 17:37:10 freenas ACPI APIC Table: <LENOVO TC-FB   >
Dec  8 17:37:10 freenas FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Dec  8 17:37:10 freenas FreeBSD/SMP: 1 package(s) x 4 core(s)
Dec  8 17:37:10 freenas cpu0 (BSP): APIC ID:  0
Dec  8 17:37:10 freenas cpu1 (AP): APIC ID:  2
Dec  8 17:37:10 freenas cpu2 (AP): APIC ID:  4
Dec  8 17:37:10 freenas cpu3 (AP): APIC ID:  6
Dec  8 17:37:10 freenas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Dec  8 17:37:10 freenas ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
Dec  8 17:37:10 freenas ioapic0 <Version 2.0> irqs 0-23 on motherboard
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_1040>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_1040_it>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_1080>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_1080_it>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_12160>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_12160_it>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2100>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2200>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2300>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2322>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2400>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2400_multi>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2500>
Dec  8 17:37:10 freenas ispfw: registered firmware <isp_2500_multi>
Dec  8 17:37:10 freenas kbd1 at kbdmux0
Dec  8 17:37:10 freenas cryptosoft0: <software crypto> on motherboard
Dec  8 17:37:10 freenas aesni0: <AES-CBC,AES-XTS> on motherboard
Dec  8 17:37:10 freenas padlock0: No ACE support.
Dec  8 17:37:10 freenas acpi0: <LENOVO TC-FB> on motherboard
Dec  8 17:37:10 freenas acpi0: Power Button (fixed)
Dec  8 17:37:10 freenas acpi0: reservation of 67, 1 (4) failed
Dec  8 17:37:10 freenas cpu0: <ACPI CPU> on acpi0
Dec  8 17:37:10 freenas cpu1: <ACPI CPU> on acpi0
Dec  8 17:37:10 freenas cpu2: <ACPI CPU> on acpi0
Dec  8 17:37:10 freenas cpu3: <ACPI CPU> on acpi0
Dec  8 17:37:10 freenas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Dec  8 17:37:10 freenas Timecounter "HPET" frequency 14318180 Hz quality 950
Dec  8 17:37:10 freenas Event timer "HPET" frequency 14318180 Hz quality 550
Dec  8 17:37:10 freenas Event timer "HPET1" frequency 14318180 Hz quality 440
Dec  8 17:37:10 freenas Event timer "HPET2" frequency 14318180 Hz quality 440
Dec  8 17:37:10 freenas Event timer "HPET3" frequency 14318180 Hz quality 440
Dec  8 17:37:10 freenas Event timer "HPET4" frequency 14318180 Hz quality 440
Dec  8 17:37:10 freenas atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
Dec  8 17:37:10 freenas atrtc0: Warning: Couldn't map I/O.
Dec  8 17:37:10 freenas Event timer "RTC" frequency 32768 Hz quality 0
Dec  8 17:37:10 freenas attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Dec  8 17:37:10 freenas Timecounter "i8254" frequency 1193182 Hz quality 0
Dec  8 17:37:10 freenas Event timer "i8254" frequency 1193182 Hz quality 100
Dec  8 17:37:10 freenas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Dec  8 17:37:10 freenas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
Dec  8 17:37:10 freenas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Dec  8 17:37:10 freenas pci0: <ACPI PCI bus> on pcib0
Dec  8 17:37:10 freenas vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0
Dec  8 17:37:10 freenas vgapci0: Boot video device
Dec  8 17:37:10 freenas pci0: <multimedia, HDA> at device 3.0 (no driver attached)
Dec  8 17:37:10 freenas pci0: <serial bus, USB> at device 20.0 (no driver attached)
Dec  8 17:37:10 freenas pci0: <simple comms> at device 22.0 (no driver attached)
Dec  8 17:37:10 freenas uart2: <Intel Lynx Point KT Controller> port 0xf0e0-0xf0e7 mem 0xf7c3e000-0xf7c3efff irq 19 at device 22.3 on pci0
Dec  8 17:37:10 freenas em0: <Intel(R) PRO/1000 Network Connection 7.4.2> port 0xf080-0xf09f mem 0xf7c00000-0xf7c1ffff,0xf7c3d000-0xf7c3dfff irq 20 at device 25.0 on pci0
Dec  8 17:37:10 freenas em0: Using an MSI interrupt
Dec  8 17:37:10 freenas em0: Ethernet address: 6c:0b:84:3e:97:2f
Dec  8 17:37:10 freenas ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7c3c000-0xf7c3c3ff irq 17 at device 26.0 on pci0
Dec  8 17:37:10 freenas usbus0: EHCI version 1.0
Dec  8 17:37:10 freenas usbus0 on ehci0
Dec  8 17:37:10 freenas pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Dec  8 17:37:10 freenas pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
Dec  8 17:37:10 freenas pci1: <ACPI PCI bus> on pcib1
Dec  8 17:37:10 freenas pcib2: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
Dec  8 17:37:10 freenas pci2: <ACPI PCI bus> on pcib2
Dec  8 17:37:10 freenas pcib3: <ACPI PCI-PCI bridge> irq 19 at device 0.0 on pci2
Dec  8 17:37:10 freenas pci3: <ACPI PCI bus> on pcib3
Dec  8 17:37:10 freenas ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7c3b000-0xf7c3b3ff irq 23 at device 29.0 on pci0
Dec  8 17:37:10 freenas usbus1: EHCI version 1.0
Dec  8 17:37:10 freenas usbus1 on ehci1
Dec  8 17:37:10 freenas isab0: <PCI-ISA bridge> at device 31.0 on pci0
Dec  8 17:37:10 freenas isa0: <ISA bus> on isab0
Dec  8 17:37:10 freenas ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf0d0-0xf0d7,0xf0c0-0xf0c3,0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf060-0xf07f mem 0xf7c3a000-0xf7c3a7ff irq 19 at device 31.2 on pci0
Dec  8 17:37:10 freenas ahci0: AHCI v1.30 with 5 6Gbps ports, Port Multiplier not supported
Dec  8 17:37:10 freenas ahcich0: <AHCI channel> at channel 0 on ahci0
Dec  8 17:37:10 freenas ahcich2: <AHCI channel> at channel 2 on ahci0
Dec  8 17:37:10 freenas ahcich4: <AHCI channel> at channel 4 on ahci0
Dec  8 17:37:10 freenas acpi_button0: <Power Button> on acpi0
Dec  8 17:37:10 freenas acpi_tz0: <Thermal Zone> on acpi0
Dec  8 17:37:10 freenas acpi_tz1: <Thermal Zone> on acpi0
Dec  8 17:37:10 freenas uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Dec  8 17:37:10 freenas orm0: <ISA Option ROM> at iomem 0xd0000-0xd0fff on isa0
Dec  8 17:37:10 freenas sc0: <System console> at flags 0x100 on isa0
Dec  8 17:37:10 freenas sc0: VGA <16 virtual consoles, flags=0x300>
Dec  8 17:37:10 freenas vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Dec  8 17:37:10 freenas atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
Dec  8 17:37:10 freenas atkbd0: <AT Keyboard> irq 1 on atkbdc0
Dec  8 17:37:10 freenas kbd0 at atkbd0
Dec  8 17:37:10 freenas atkbd0: [GIANT-LOCKED]
Dec  8 17:37:10 freenas wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
Dec  8 17:37:10 freenas coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Dec  8 17:37:10 freenas est0: <Enhanced SpeedStep Frequency Control> on cpu0
Dec  8 17:37:10 freenas coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Dec  8 17:37:10 freenas est1: <Enhanced SpeedStep Frequency Control> on cpu1
Dec  8 17:37:10 freenas coretemp2: <CPU On-Die Thermal Sensors> on cpu2
Dec  8 17:37:10 freenas est2: <Enhanced SpeedStep Frequency Control> on cpu2
Dec  8 17:37:10 freenas coretemp3: <CPU On-Die Thermal Sensors> on cpu3
Dec  8 17:37:10 freenas est3: <Enhanced SpeedStep Frequency Control> on cpu3
Dec  8 17:37:10 freenas ZFS filesystem version: 5
Dec  8 17:37:10 freenas ZFS storage pool version: features support (5000)
Dec  8 17:37:10 freenas Timecounters tick every 1.000 msec
Dec  8 17:37:10 freenas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Dec  8 17:37:10 freenas usbus0: 480Mbps High Speed USB v2.0
Dec  8 17:37:10 freenas usbus1: 480Mbps High Speed USB v2.0
Dec  8 17:37:10 freenas ugen0.1: <Intel> at usbus0
Dec  8 17:37:10 freenas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Dec  8 17:37:10 freenas ugen1.1: <Intel> at usbus1
Dec  8 17:37:10 freenas uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Dec  8 17:37:10 freenas uhub0: 3 ports with 3 removable, self powered
Dec  8 17:37:10 freenas uhub1: 3 ports with 3 removable, self powered
Dec  8 17:37:10 freenas ugen0.2: <vendor 0x8087> at usbus0
Dec  8 17:37:10 freenas uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.04, addr 2> on usbus0
Dec  8 17:37:10 freenas ugen1.2: <vendor 0x8087> at usbus1
Dec  8 17:37:10 freenas uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.04, addr 2> on usbus1
Dec  8 17:37:10 freenas uhub2: 6 ports with 6 removable, self powered
Dec  8 17:37:10 freenas uhub3: 8 ports with 8 removable, self powered
Dec  8 17:37:10 freenas ugen1.3: <Kingston> at usbus1
Dec  8 17:37:10 freenas umass0: <Kingston DataTraveler G3, class 0/0, rev 2.00/1.00, addr 3> on usbus1
Dec  8 17:37:10 freenas umass0:  SCSI over Bulk-Only; quirks = 0x4000
Dec  8 17:37:10 freenas umass0:4:0:-1: Attached to scbus4
Dec  8 17:37:10 freenas ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Dec  8 17:37:10 freenas ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device
Dec  8 17:37:10 freenas ada0: Serial Number WD-WMAZA2737311
Dec  8 17:37:10 freenas da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
Dec  8 17:37:10 freenas da0: <Kingston DataTraveler G3 PMAP> Removable Direct Access SCSI-0 device
Dec  8 17:37:10 freenas da0: Serial Number 001D0F0CCF5CBA70431606FA
Dec  8 17:37:10 freenas da0: 40.000MB/s transfers
Dec  8 17:37:10 freenas da0: 7628MB (15622144 512 byte sectors: 255H 63S/T 972C)
Dec  8 17:37:10 freenas da0: quirks=0x2<NO_6_BYTE>
Dec  8 17:37:10 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec  8 17:37:10 freenas ada0: Command Queueing enabled
Dec  8 17:37:10 freenas ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:37:10 freenas ada0: quirks=0x1<4K>
Dec  8 17:37:10 freenas ada0: Previously was known as ad4
Dec  8 17:37:10 freenas ada1 at ahcich2 bus 0 scbus1 target 0 lun 0
Dec  8 17:37:10 freenas ada1: <TOSHIBA MD04ACA500 FP2A> ATA-8 SATA 3.x device
Dec  8 17:37:10 freenas ada1: Serial Number 85OCK0G5FS9A
Dec  8 17:37:10 freenas ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec  8 17:37:10 freenas ada1: Command Queueing enabled
Dec  8 17:37:10 freenas ada1: 4769307MB (9767541168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:37:10 freenas ada1: Previously was known as ad6
Dec  8 17:37:10 freenas ada2 at ahcich4 bus 0 scbus2 target 0 lun 0
Dec  8 17:37:10 freenas ada2: <TOSHIBA MD04ACA500 FP2A> ATA-8 SATA 3.x device
Dec  8 17:37:10 freenas ada2: Serial Number 9542KDLPFS9A
Dec  8 17:37:10 freenas ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec  8 17:37:10 freenas ada2: Command Queueing enabled
Dec  8 17:37:10 freenas ada2: 4769307MB (9767541168 512 byte sectors: 16H 63S/T 16383C)
Dec  8 17:37:10 freenas ada2: Previously was known as ad8
Dec  8 17:37:10 freenas SMP: AP CPU #3 Launched!
Dec  8 17:37:10 freenas SMP: AP CPU #1 Launched!
Dec  8 17:37:10 freenas SMP: AP CPU #2 Launched!
Dec  8 17:37:10 freenas Timecounter "TSC-low" frequency 1596340737 Hz quality 1000
Dec  8 17:37:10 freenas Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648 []...
Dec  8 17:37:10 freenas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
Dec  8 17:37:10 freenas root: /etc/rc: WARNING: failed to start watchdogd
Dec  8 17:37:11 freenas GEOM_ELI: Device ada2p1.eli created.
Dec  8 17:37:11 freenas GEOM_ELI: Encryption: AES-XTS 256
Dec  8 17:37:11 freenas GEOM_ELI:     Crypto: hardware
Dec  8 17:37:11 freenas GEOM_ELI: Device ada1p1.eli created.
Dec  8 17:37:12 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Dec  8 17:37:12 freenas vboxdrv: fAsync=0 offMin=0x2db offMax=0xf80
Dec  8 17:37:15 freenas ntpd[2067]: ntpd 4.2.4p5-a (1)
Dec  8 17:37:20 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /usr/local/bin/net -d 0 getlocalsid
Dec  8 17:37:20 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Dec  8 17:37:20 freenas generate_smb4_conf.py: [common.pipesubr:71] Popen()ing: zfs list -H -o mountpoint
Dec  8 17:37:21 freenas nmbd[2335]: [2015/12/08 17:37:21.180330,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:37:21 freenas winbindd[2341]: [2015/12/08 17:37:21.281064,  0] ../source3/winbindd/winbindd_cache.c:3196(initialize_winbindd_cache)
Dec  8 17:37:21 freenas winbindd[2341]:   initialize_winbindd_cache: clearing cache and re-creating with version number 2
Dec  8 17:37:21 freenas winbindd[2341]: [2015/12/08 17:37:21.284755,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:37:22 freenas smbd[2338]: [2015/12/08 17:37:22.178143,  0] ../lib/util/become_daemon.c:136(daemon_ready)
Dec  8 17:37:22 freenas smbd[2338]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec  8 17:37:22 freenas smartd[2344]: Device: /dev/ada0, 33 Currently unreadable (pending) sectors
Dec  8 17:37:22 freenas smartd[2344]: Device: /dev/ada0, 12 Offline uncorrectable sectors
Dec  8 17:37:23 freenas smbd[2338]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec  8 17:37:44 freenas nmbd[2335]:   STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
Dec  8 17:37:44 freenas nmbd[2335]:   Samba name server FREENAS is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.12
Dec  8 17:37:45 freenas syslog-ng[3716]: syslog-ng starting up; version='3.5.6'
Dec  8 17:37:45 freenas kernel: pid 1682 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Dec  8 17:38:09 freenas ntpd[2068]: time reset -0.543216 s
Dec  8 18:07:23 freenas smartd[2359]: Device: /dev/ada0, 33 Currently unreadable (pending) sectors
Dec  8 18:07:23 freenas smartd[2359]: Device: /dev/ada0, 12 Offline uncorrectable sectors
Dec  8 18:37:23 freenas smartd[2359]: Device: /dev/ada0, 33 Currently unreadable (pending) sectors
Dec  8 18:37:23 freenas smartd[2359]: Device: /dev/ada0, 12 Offline uncorrectable sectors
Dec  8 18:39:01 freenas smbd[5181]:   STATUS=daemon 'smbd' finished starting up and ready to serve connectionsmatchname: host name/name mismatch: 192.168.0.14 != (NULL)
Dec  8 18:39:01 freenas smbd[5181]: [2015/12/08 18:39:01.865561,  0] ../source3/lib/util_sock.c:1199(get_remote_hostname)
Dec  8 18:39:01 freenas smbd[5181]:   matchname failed on 192.168.0.14
Cephyid
This is the code from SSH'ing in with Putty
[root@freenas] /var/log# tail -100 messages
Dec  8 17:37:10 freenas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, a        ddr 1> on usbus0
Dec  8 17:37:10 freenas uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, a        ddr 1> on usbus1
Dec  8 17:37:10 freenas uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.0        0/0.04, addr 2> on usbus0
Dec  8 17:37:10 freenas uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.0        0/0.04, addr 2> on usbus1
Dec  8 17:37:10 freenas umass0: <Kingston DataTraveler G3, class 0/0, rev 2.00/1        .00, addr 3> on usbus1
Dec  8 17:37:10 freenas ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x dev        ice
Dec  8 17:37:10 freenas da0: <Kingston DataTraveler G3 PMAP> Removable Direct Ac        cess SCSI-0 device
Dec  8 17:37:10 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192by        tes)
Dec  8 17:37:10 freenas ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192by        tes)
Dec  8 17:37:10 freenas ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192by        tes)
Dec  8 17:37:10 freenas Timecounter "TSC-low" frequency 1596340737 Hz quality 10        00
Dec  8 17:37:10 freenas Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-        9.3-STABLE-201511280648 []...
Dec  8 17:37:10 freenas wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xf        f DevRev 0xff CR26 0xff
Dec  8 17:37:12 freenas root: /etc/rc: WARNING: failed precmd routine for vmware        _guestd
Dec  8 17:37:21 freenas nmbd[2335]: [2015/12/08 17:37:21.180330,  0] ../lib/util        /become_daemon.c:136(daemon_ready)
Dec  8 17:37:21 freenas winbindd[2341]: [2015/12/08 17:37:21.281064,  0] ../sour        ce3/winbindd/winbindd_cache.c:3196(initialize_winbindd_cache)
Dec  8 17:37:21 freenas winbindd[2341]:   initialize_winbindd_cache: clearing ca        che and re-creating with version number 2
Dec  8 17:37:21 freenas winbindd[2341]: [2015/12/08 17:37:21.284755,  0] ../lib/        util/become_daemon.c:136(daemon_ready)
Dec  8 17:37:22 freenas smbd[2338]: [2015/12/08 17:37:22.178143,  0] ../lib/util        /become_daemon.c:136(daemon_ready)
Dec  8 17:37:22 freenas smbd[2338]: dnssd_clientstub ConnectToServer: connect()-        > No of tries: 1
Dec  8 17:37:22 freenas smartd[2344]: Device: /dev/ada0, 12 Offline uncorrectabl        e sectors
Dec  8 17:37:23 freenas smbd[2338]: dnssd_clientstub ConnectToServer: connect()-        > No of tries: 2
Dec  8 17:37:44 freenas nmbd[2335]:   Samba name server FREENAS is now a local m        aster browser for workgroup WORKGROUP on subnet 192.168.0.12
Dec  8 18:07:23 freenas smartd[2359]: Device: /dev/ada0, 12 Offline uncorrectabl        e sectors
Dec  8 18:37:23 freenas smartd[2359]: Device: /dev/ada0, 12 Offline uncorrectabl        e sectors
Dec  8 18:39:01 freenas smbd[5181]:   STATUS=daemon 'smbd' finished starting up        and ready to serve connectionsmatchname: host name/name mismatch: 192.168.0.14 !        = (NULL)
Dec  8 18:39:01 freenas smbd[5181]: [2015/12/08 18:39:01.865561,  0] ../source3/        lib/util_sock.c:1199(get_remote_hostname)
Bidule0hm
Server Electronics Sorcerer
Can you post the output of smartctl -a /dev/ada0 please?
Cephyid
[root@freenas] ~# smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family:     Western Digital Caviar Green (AF)
Device Model:     WDC WD20EARS-00MVWB0
Serial Number:    WD-WMAZA2737311
LU WWN Device Id: 5 0014ee 600c31547
Firmware Version: 51.0AB51
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Tue Dec  8 21:57:01 2015 COT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x05) Offline data collection activity
                                        was aborted by an interrupting command from host.
Self-test execution status:      ( 245) Self-test routine in progress...
                                        50% of test remaining.
data collection:                (36180) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 349) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   196   195   051    Pre-fail  Always       -       2804
  3 Spin_Up_Time            0x0027   253   167   021    Pre-fail  Always       -       1091
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2005
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6095
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1017
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       30
193 Load_Cycle_Count        0x0032   184   184   000    Old_age   Always       -       48754
194 Temperature_Celsius     0x0022   116   110   000    Old_age   Always       -       34
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       33
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       12
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   199   196   000    Old_age   Offline      -       291
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      6092         -
# 2  Short offline       Completed without error       00%      6076         -
# 3  Short offline       Completed without error       00%      6075         -
Robert Trevellyan
Pony Wrangler
A short SMART test can pass even with non-zero valued for any or all of #5, #197 and #198, as long as the predefined threshold isn't reached. Read up on SMART attributes in Wikipedia to understand why. However, it makes FreeNAS nervous, hence the warnings.
Run an extended SMART test on the drive. If it fails, run an ATA reset on it. If that succeeds, run a badblocks destructive write test on it. If that comes back clean, deploy it but keep a close eye on it for rising valued in #5, #197 or #198. Or just save all the trouble and replace it now.
Cephyid
Local Time is:    Wed Dec  9 10:29:22 2015 COT
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6108
193 Load_Cycle_Count        0x0032   184   184   000    Old_age   Always       -       48773
194 Temperature_Celsius     0x0022   123   110   000    Old_age   Always       -       27
200 Multi_Zone_Error_Rate   0x0008   195   195   000    Old_age   Offline      -       1507
No Errors Logged
# 1  Extended offline    Completed without error       00%      6098         -
# 2  Short offline       Completed without error       00%      6092         -
# 3  Short offline       Completed without error       00%      6076         -
# 4  Short offline       Completed without error       00%      6075         -
It doesn't appear to have failed. I still have to deal with those pending sectors though.
Robert Trevellyan
Pony Wrangler
An ATA reset or a destructive badblocks will take care of the pending sectors, assuming the drive is fundamentally healthy. Don't deploy it the way it is now. Also consider an RMA - it's less than a year old.
EDIT: I should say, it has less than a year of usage. Obviously I have no idea how long you've had it.
Cephyid
I've had both 2TB drives since 2010 or 2011 I think so no RMA. I bought them when hard drive prices were super low but they've mostly been unused. I'm running a long test on the other one and I'll run destructive badblocks on both when it's done. That should force a rewrite and hopefully get those sectors out of pending. I'm going to mirror them and have a backup on an external. My next step will be figuring out incremental backups and regular SMART tests.
Thanks for the help.
Robert Trevellyan
Pony Wrangler
Sounds like a plan. Finally, don't forget to schedule short and extended SMART tests and make sure email notifications are working.
ATA reset is also known as ATA secure erase. My go-to for this is a Redo Backup live CD - look for the Drive Reset utility. Another way is using the disk erase button in the Disk Utility in Ubuntu, which you can also run from a live DVD or USB stick.
Cephyid
Finished badblocks and a long test. I still have 4 pending sectors and it failed the extended test. What next?
  1 Raw_Read_Error_Rate     0x002f   195   194   051    Pre-fail  Always       -       4396
  3 Spin_Up_Time            0x0027   253   167   021    Pre-fail  Always       -       1108
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2007
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6190
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1019
193 Load_Cycle_Count        0x0032   184   184   000    Old_age   Always       -       48849
194 Temperature_Celsius     0x0022   122   110   000    Old_age   Always       -       28
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       4
200 Multi_Zone_Error_Rate   0x0008   199   195   000    Old_age   Offline      -       380
No Errors Logged
# 1  Extended offline    Completed: read failure       90%      6181         220165200
# 2  Conveyance offline  Completed without error       00%      6118         -
# 3  Extended offline    Completed without error       00%      6098         -
# 4  Short offline       Completed without error       00%      6092         -
# 5  Short offline       Completed without error       00%      6076         -
# 6  Short offline       Completed without error       00%      6075         -
Cephyid
If I execute this is it correct?
dd if=/dev/zero of=/dev/ada0 bs=512 count=1 seek=220165200 conv=noerror,sync
The bs= is supposed to be 512 like SMART says or 4096?
Cephyid
I have tried to do a drive reset btw but the drive is FROZEN (https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase) and I can't unfreeze it. I don't see any security settings in the bios and hot un/plugging the SATA cable doesn't do anything for me.
Edit: I don't think it's possible on the TS140 due to the bios. I'd have to move the drive to my computer to try. Maybe tomorrow.
Robert Trevellyan
Pony Wrangler
You're sure you did the the destructive write test?
You can usually avoid this by only powering up the drive after the system has booted. A drive dock makes this easy.
Cephyid
I did the one with the -ws modifier so I'm pretty sure. I tried to get around the freeze by unplugging the drives SATA and replugging it in but that didn't work.
I'm having fun figuring all this out and messing around but I'm trying to get to the bottom of this. Decided to write zeros to the drive with dd but came home to find I was barely 15% complete after like 8 hours. Looked it up and realized I was writing one byte at a time so changed it to bs=100M.
If I'm understanding this correctly then it should force a reallocation but so should the badblocks test I thought. We'll see tomorrow how it goes after another long test.
Robert Trevellyan
Pony Wrangler
That's the one. Did it report any errors? If it didn't make the drive remap the bad sectors, the drive is probably junk at this point, and I don't think dd will help.
I use a Redo Backup live CD and a drive dock for the ATA Secure Erase, which gets around the FROZEN issue. If you don't have a drive dock, at least try connecting the drive after the machine has booted.
Cephyid
Badblocks didn't report errors directly but the long test afterwards did. I didn't quite know how to remap just the selected LBA so I was trying the ATA format and then ultimately writing zeroes to the drive.
When I booted the machine for the ATA reset I had the hard drive plugged in but then unplugged it and replugged it back in after boot. Would it maybe have worked if I simply tried booting with no hard drive attached and then attached it?
Either way I believe the zeroes and last extended test show a usable drive now. I have 0 pending sectors. It also shows 0 reallocated though which is a bit perplexing. Still it went from 33 pending to 4 after badblocks and now to 0 after writing zeroes to the drive.
The multizone error rate also dropped from 1507 to 380 and now to 128.
Am I good to set this up in a mirror now you think? With backups of course.
Local Time is:    Mon Dec 14 11:01:10 2015 COT
                                        been run.
                                        command.
                                        power-saving mode.
  3 Spin_Up_Time            0x0027   253   167   021    Pre-fail  Always       -       1000
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2023
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6226
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1035
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       40
193 Load_Cycle_Count        0x0032   184   184   000    Old_age   Always       -       48888
194 Temperature_Celsius     0x0022   120   110   000    Old_age   Always       -       30
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   195   000    Old_age   Offline      -       128
No Errors Logged
# 1  Extended offline    Completed without error       00%      6223         -
# 2  Extended offline    Completed: read failure       90%      6191         34322632
# 3  Extended offline    Completed: read failure       90%      6181         220165200
# 4  Conveyance offline  Completed without error       00%      6118         -
# 5  Extended offline    Completed without error       00%      6098         -
# 6  Short offline       Completed without error       00%      6092         -
# 7  Short offline       Completed without error       00%      6076         -
# 8  Short offline       Completed without error       00%      6075         -
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1
Robert Trevellyan
Pony Wrangler
According to the Wikepedia explanation of SATA attributes, a pending sector reallocation that results from a read failure can go away following a successful write to that sector, which can mask underlying problems with the physical medium. I'd keep a close eye on it.
EDIT: especially considering you have Offline_Uncorrectable in double figures: "The total count of uncorrectable errors when reading/writing a sector. A rise in the value of this attribute indicates defects of the disk surface and/or problems in the mechanical subsystem."
