I've done some cursory searches and fond mixed suggestions for my scenario.
Server Configuration:
TrueNAS Core
Intel Xeon Gold 5317 - 12-cores
512GB RAM
10x Micron NVME 7450 MAX - 12.8TB drives
2x Supermicro Dual-Port Gen-4 Internal NVMe Host Bus Adapter - PCI-E x8
2x Supermicro Quad-Port Gen-4 Internal NVMe Host Bus Adapter - PCI-E x16
22 Hot Swap NVME bays
2 Hot Swap SSD bays
I am looking for a configuration to use for ESXi data stores, presenting either NFS or ISCSI. I'm not partial to either. I have two 10 Gbit NICs dedicated for storage connectivity to ESXi.
I'm looking for reasonable capacity but prefer performance for this datastore, which will be used for virtual machine VMDKs, so a level of resiliancy against drive failures is needed. what would be the ideal drive configuration for this use case?
With NVME drives, is there a ned for a SLOG or L2ARC?
Thank you for entertaining the noob questions.
TrueNAS Core
512GB RAM
2 Hot Swap SSD bays
