DonZalmrol
 - Oct 6, 2021
Hi all,
I'm doubting between (currently) 2 HBA controllers for my HP DL380G9 server. At the moment I'm using the build-in HP P440AR controller in HBA mode, this is apperantly not a true HBA controller, does not provide SMART readings, uses the CCISS driver and quoting @jgreco :
My current set up is
Anybody that has either card that can tell their experiences about them?
Thx!
This isn't compatible with TrueNAS, please refer to
What's all the noise about HBAs, and why can't I use a RAID controller?
The CCISS driver is not particularly robust and putting it in a lobotomized "HBA mode" does not fix this; it just makes it a moronic RAID controller. You should replace the Smart Array controller with a true HBA if you want problem-free operation.
- HP DL380 Gen9
 - HP P440AR controller in HBA mode
 - HPE 12Gb SAS Expander Card
 - 128GB RAM DDR4 ECC
 - Intel Xeon E5-2630L v3 @ 1.80GHz
 - Nvidia Quadro P2000 5GB
 - 2x Intel SSD 120GB boot-pool
 - 2x Samsung SSD 512 mirrored pool for APPS storage
 - 5x 14TB HGST DC HC530 for DATA storage
- The LSI 9207-8i 6Gbs SAS 2308 PCI-E 3.0 HBA IT Mode
- Pros:
- Cheap
 - Well known
 - SFF-8087 (my current cables)
 - 6Gb/s SAS performance (I have SATA disks)
 - Cons:
- Old
 - SAS2
 - 600MB/s
 - Pros:
 - LSI SAS 9300-16i 16-Port 12Gb/s SAS-3
- Pros:
- Newer
 - 12Gb/s
 - SAS3
 - Cons:
- Expensive
 - SFF-8644 (need new cables)
 - Pros:
Thx!
