Floyd
- May 7, 2014
I have a ASRock Rack `E3C236D2I - Mini-ITX` motherboard that comes with two `2 x RJ45 Ethernet` ports. I'm using to run TrueNas Core v12 on.
I noticed that one Ethernet jack is using the `em` driver the other is using the `igb` driver.
So I'm wondering if this is a problem. Both ports work fine and I don't notice much difference in speeds (although it's hard to tell with my slow home network) but the point is, does make sense to do? And if not should I switch them to use the same driver. If so which would be the preferred one to use.
Thanks in advance,
Floyd
Thanks in advance,
Floyd
