Hello!
I recently bought a pretty muych complete server on eBay and am trying to check if everything works as it should. I stumpled upon some issue and am not sure if they are due to improper configuration or maybe faulty parts. The parts that I got are the following:
I am having the following problem: I am not able to 'see' the drives in FreeNAS in a couple of different configurations. I tried the following
- X9DRi-LN4F+ with the newest BIOS version (32 Gigabyte RAM and 2 pcs Xeon 2609 v2)
- Adaptec 5405
- CBL-0421L
- BPN-SAS2-846EL
- I used the Apdaptec 5405 and connect it to the backplanes J0 with the CBL-0421L. I can see the drives with an incorrect capacity (2TB instead of 4TB) in the Adaptec configuration when booting but not in FreeNAS. Googling showed me that someone made it work after adding them to a JBOD. I did that as well but nothing changed.
- I connected the motherboards SCU to the backplane with the CBL-0421L and nothing shows up as well. After googling I found https://forums.freenas.org/index.php?threads/how-to-use-scu-port-on-x9dri-ln4f.40007/#post-318017/ where Stux' comment suggest that this is not supposed to work anyway and - as I understand it - a proper SAS expander is needed.
