Disks OK, but pool gone with lots of WRITE_FPDMA_QUEUED, ACB CAM status, ATA Status Error ATA status, ...
alterfritz72
quite new to freenas. Build some freenas server on commodity hardware. I attached dmesg output.
I have build a pool based on 3x10 disks on RAIDz2.
I was coping some date overnight, all seems good. Im the morning, the pool was done. An lots of errors are in the /var/log/messages.
It seems to me that the disks are ok, 1st they are quite new, and second I removed on and did some smart test also in a windows pc. There are no permanent errors on those disks, like bad blocks.
However, it seems that all the times I try a zpool import, it hangs like this:
Oct 27 10:48:23 freenas1 nfsd: can't register svc name
Oct 27 10:48:23 freenas1 ntpd[1370]: restrict: ignoring line 10, address/host '0.freebsd.pool.ntp.org' unusable.
Oct 27 10:48:23 freenas1 ntpd[1370]: restrict: ignoring line 11, address/host '1.freebsd.pool.ntp.org' unusable.
Oct 27 10:48:23 freenas1 ntpd[1370]: restrict: ignoring line 12, address/host '2.freebsd.pool.ntp.org' unusable.
Oct 27 10:48:24 freenas1 kernel: re0: link state changed to UP
Oct 27 10:48:24 freenas1 nfsrv_cache_session: no session
**** here I start the import from another shell ****
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3741448112455685757
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4664470457175269676
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=8685132275913437468
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=8231545775239736065
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4194145620947548577
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=6395447668334150041
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3247671384774872601
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=16912913949041146380
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4529362423629436642
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12884665542282722123
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12366843741750379281
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=18388331534813110478
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=17314746444696464833
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=2004171900423069180
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=1756946791324882113
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=13520873478109463645
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=8800604598952879030
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=9131285662896745831
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4922909577835814258
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12937972062917121217
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12259229670344092347
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4932022763362024582
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=14492331186460395707
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=5139867809909229828
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3782388242098230347
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=14154430933037967269
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=13595744289878905008
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4950188485396152737
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=14828035688722699969
Oct 27 11:01:23 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3643098206646759999
Oct 27 11:01:31 freenas1 ahcich3: Timeout on slot 7 port 0
Oct 27 11:01:31 freenas1 ahcich3: is 00000000 cs 00000080 ss 00000000 rs 00000080 tfd 58 serr 00000000 cmd 0004c717
Oct 27 11:01:31 freenas1 ahcich3: Error while READ LOG EXT
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 02 40 40 00 00 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): CAM status: ATA Status Error
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): ATA status: 00 ()
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): RES: 00 00 00 00 00 00 00 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): Retrying command
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 01 86 be c0 40 d1 01 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 ba c0 40 d1 01 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 bc c0 40 d1 01 00 00 00 00
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): SETFEATURES SET TRANSFER MODE. ACB: ef 03 00 00 00 40 00 00 00 00 46 00
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): CAM status: ATA Status Error
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): ATA status: 61 (DRDY DF ERR), error: 04 (ABRT )
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): RES: 61 04 00 00 00 40 00 00 00 46 00
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): Retrying command
Oct 27 11:01:31 freenas1 (aprobe0:ahcich3:0:0:0): Error 5, Retries exhausted
Oct 27 11:01:31 freenas1 ada7 at ahcich3 bus 0 scbus3 target 0 lun 0
Oct 27 11:01:31 freenas1 ada7: <WDC WD40EFAX-68JH4N0 82.00A82> s/n WD-WX32D203U3JT detached
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): SETFEATURES ENABLE RCACHE. ACB: ef aa 00 00 00 40 00 00 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): ATA status: 61 (DRDY DF ERR), error: 04 (ABRT )
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): RES: 61 04 00 00 00 40 00 00 00 00 00
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): Error 5, Periph was invalidated
Oct 27 11:01:31 freenas1 (ada7:ahcich3:0:0:0): SETFEATURES ENABLE WCACHE. ACB: ef 02 00 00 00 40 00 00 00 00 00 00
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3741448112455685757
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4664470457175269676
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=8685132275913437468
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=8231545775239736065
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4194145620947548577
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=6395447668334150041
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=3247671384774872601
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=16912913949041146380
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=4529362423629436642
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12884665542282722123
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=12366843741750379281
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=18388331534813110478
Oct 27 11:01:39 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=17314746444696464833
Oct 27 11:01:39 freenas1 ahcich3: Timeout on slot 17 port 0
Oct 27 11:01:39 freenas1 ahcich3: is 00000000 cs 00020000 ss 00000000 rs 00020000 tfd 58 serr 00000000 cmd 0004d117
Oct 27 11:01:39 freenas1 ahcich3: Error while READ LOG EXT
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 02 40 40 00 00 00 00 00 00
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): CAM status: ATA Status Error
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): ATA status: 00 ()
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): RES: 00 00 00 00 00 00 00 00 00 00 00
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): Error 5, Periph was invalidated
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 01 86 be c0 40 d1 01 00 00 00 00
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 ba c0 40 d1 01 00 00 00 00
Oct 27 11:01:39 freenas1 (ada7:ahcich3:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 bc c0 40 d1 01 00 00 00 00
Oct 27 11:01:39 freenas1 g_access(952): provider ada7 has error 6 set
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): WRITE_DMA. ACB: ca 00 90 02 40 40 00 00 00 00 10 00
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): CAM status: ATA Status Error
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): ATA status: 61 (DRDY DF ERR), error: 04 (ABRT )
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): RES: 61 04 90 02 40 00 00 00 00 10 00
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): Retrying command
Oct 27 11:01:39 freenas1 (ada27:ata9:0:0:0): Error 5, Retries exhausted
This then goes on forever - the pool does not get online again, even in degraded state.
What I do not understand - if the disks are gone by physical defect I would understand, but if they are OK and its just the data - how that could happen? Again seems to me the disks are physically OK
And if there a way to fix that, somehow identify the bad data and zero is, so the pool comes online again, maybe in degraded state?
II also tried the following,:
1.) get a list of all disks / ada identifiers
2.) start a zpool import, identify the disks its complaining about, unplug stata, reboot...
3.) do that for the next disk, start with 1^.)
I also smartest data for all drives, also attached. In this smarttest.log you can see that those strange smart errors have been recorded on a few disks, like ada7:
* ada7*
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p14 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (SMR)
Device Model: WDC WD40EFAX-68JH4N0
Serial Number: WD-WX32D203U3JT
LU WWN Device Id: 5 0014ee 21272c9f7
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Oct 27 15:19:41 2020 CET
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (36060) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 517) minutes.
Conveyance self-test routine
SCT capabilities: (0x3039) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 198 195 021 Pre-fail Always - 3091
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 434
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1668
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 417
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 325
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 125
194 Temperature_Celsius 0x0022 115 090 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 30 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 30 occurred at disk power-on lifetime: 1668 hours (69 days + 12 hours)
ER ST SC SN CL CH DH
04 61 46 00 00 00 40 Device Fault; Error: ABRT
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ef 03 46 00 00 00 40 08 00:08:53.086 SET FEATURES [Set transfer mode]
ec 00 00 00 00 00 40 08 00:08:53.085 IDENTIFY DEVICE
Error 29 occurred at disk power-on lifetime: 1668 hours (69 days + 12 hours)
Error 28 occurred at disk power-on lifetime: 1668 hours (69 days + 12 hours)
04 61 00 00 00 00 40 Device Fault; Error: ABRT
ef 02 00 00 00 00 40 08 00:08:45.004 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 40 08 00:08:45.003 SET FEATURES [Enable read look-ahead]
ef 03 46 00 00 00 40 08 00:08:45.003 SET FEATURES [Set transfer mode]
ec 00 00 00 00 00 40 08 00:08:45.002 IDENTIFY DEVICE
Error 27 occurred at disk power-on lifetime: 1668 hours (69 days + 12 hours)
Error 26 occurred at disk power-on lifetime: 1668 hours (69 days + 12 hours)
# 1 Short offline Completed without error 00% 1646 -
# 2 Short offline Completed without error 00% 1646 -
# 3 Short offline Completed without error 00% 1646 -
# 4 Short offline Completed without error 00% 1645 -
# 5 Short offline Completed without error 00% 1623 -
# 6 Short offline Completed without error 00% 1622 -
# 7 Short offline Completed without error 00% 1598 -
# 8 Short offline Completed without error 00% 1574 -
# 9 Short offline Completed without error 00% 1550 -
#10 Short offline Completed without error 00% 1526 -
#11 Short offline Completed without error 00% 1502 -
#12 Short offline Completed without error 00% 1478 -
#13 Short offline Completed without error 00% 1454 -
#14 Short offline Completed without error 00% 1430 -
#15 Short offline Completed without error 00% 1410 -
#16 Short offline Completed without error 00% 1385 -
#17 Short offline Completed without error 00% 1362 -
#18 Short offline Completed without error 00% 1361 -
#19 Short offline Completed without error 00% 1337 -
#20 Short offline Completed without error 00% 1313 -
#21 Short offline Completed without error 00% 1293 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
So in summary I think
1.) the disks are physically OK, but somehow the data got corrupted.
2.) I guess as that affected more then 2 disks in one vdev the data is gone, correct
3.) if there have been any way to recover even in degraded state zfs would have done when I execute zpool import
Before I delete and restart - please can someone with more experience tell me if there is any way to save the data, even partially I read somewhere you may detect the parts that are bad on each disk and zero them out. Is something like that possible?
Many thanks
Joerg
  • dmesg.out.txt
  • smarttest.log.txt
alterfritz72
Let me add something - what I have not tried is import with read-only.
That brings the pool online, but when I try to copy the files back to safety, it starts again in the logs...
Oct 28 15:03:13 freenas1 ada8 at ahcich8 bus 0 scbus8 target 0 lun 0
Oct 28 15:03:13 freenas1 ada8: <WDC WD40EFAX-68JH4N0 82.00A82> s/n WD-WX22D50E8CV1 detached
Oct 28 15:03:13 freenas1 ada6 at ahcich6 bus 0 scbus6 target 0 lun 0
Oct 28 15:03:13 freenas1 ada6: <WDC WD40EFAX-68JH4N0 82.00A82> s/n WD-WX22D50JUPC7 detached
Oct 28 15:03:43 freenas1 ahcich17: Timeout on slot 11 port 4
Oct 28 15:03:43 freenas1 ahcich17: is 00000000 cs 00000000 ss 00000800 rs 00000800 tfd 50 serr 00400000 cmd 00731717
Oct 28 15:03:43 freenas1 (ada21:ahcich17:0:4:0): READ_FPDMA_QUEUED. ACB: 60 08 28 0b 8d 40 d4 00 00 00 00 00
Oct 28 15:03:43 freenas1 (ada21:ahcich17:0:4:0): CAM status: Command timeout
Oct 28 15:03:43 freenas1 (ada21:ahcich17:0:4:0): Retrying command
Oct 28 15:03:44 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=18388331534813110478
Oct 28 15:03:44 freenas1 ZFS: vdev is removed, pool_guid=6764645390058751664 vdev_guid=18388331534813110478
Oct 28 15:03:44 freenas1 ZFS: vdev state changed, pool_guid=6764645390058751664 vdev_guid=17314746444696464833
Oct 28 15:03:44 freenas1 ZFS: vdev is removed, pool_guid=6764645390058751664 vdev_guid=17314746444696464833
Oct 28 15:03:44 freenas1 (ada6:ahcich6:0:0:0): Periph destroyed
Oct 28 15:03:44 freenas1 ada6 at ahcich6 bus 0 scbus6 target 0 lun 0
Oct 28 15:03:44 freenas1 ada6: <WDC WD40EFAX-68JH4N0 82.00A82> ACS-3 ATA SATA 3.x device
Oct 28 15:03:44 freenas1 ada6: Serial Number WD-WX22D50JUPC7
Oct 28 15:03:44 freenas1 ada6: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Oct 28 15:03:44 freenas1 ada6: Command Queueing enabled
Oct 28 15:03:44 freenas1 ada6: 3815447MB (7814037168 512 byte sectors)
Oct 28 15:03:44 freenas1 (ada8:ahcich8:0:0:0): Periph destroyed
Oct 28 15:03:44 freenas1 ada8 at ahcich8 bus 0 scbus8 target 0 lun 0
Oct 28 15:03:44 freenas1 ada8: <WDC WD40EFAX-68JH4N0 82.00A82> ACS-3 ATA SATA 3.x device
Oct 28 15:03:44 freenas1 ada8: Serial Number WD-WX22D50E8CV1
Oct 28 15:03:44 freenas1 ada8: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Oct 28 15:03:44 freenas1 ada8: Command Queueing enabled
Oct 28 15:03:44 freenas1 ada8: 3815447MB (7814037168 512 byte sectors)
Oct 28 15:03:44 freenas1 ada8: <WDC WD40EFAX-68JH4N0 82.00A82> s/n WD-WX22D50E8CV1 detached
Oct 28 15:03:44 freenas1 ada6: <WDC WD40EFAX-68JH4N0 82.00A82> s/n WD-WX22D50JUPC7 detached
Oct 28 15:03:51 freenas1 ada6 at ahcich6 bus 0 scbus6 target 0 lun 0
Oct 28 15:03:51 freenas1 ada6: <WDC WD40EFAX-68JH4N0 82.00A82> ACS-3 ATA SATA 3.x device
Oct 28 15:03:51 freenas1 ada6: Serial Number WD-WX22D50JUPC7
Oct 28 15:03:51 freenas1 ada6: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Oct 28 15:03:51 freenas1 ada6: Command Queueing enabled
Oct 28 15:03:51 freenas1 ada6: 3815447MB (7814037168 512 byte sectors)
Oct 28 15:03:51 freenas1 ses0: ada6,pass7 in 'Slot 02', SATA Slot: scbus6 target 0
Oct 28 15:03:51 freenas1 ada8 at ahcich8 bus 0 scbus8 target 0 lun 0
Oct 28 15:03:51 freenas1 ada8: <WDC WD40EFAX-68JH4N0 82.00A82> ACS-3 ATA SATA 3.x device
Oct 28 15:03:51 freenas1 ada8: Serial Number WD-WX22D50E8CV1
Oct 28 15:03:51 freenas1 ada8: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Oct 28 15:03:51 freenas1 ada8: Command Queueing enabled
Oct 28 15:03:51 freenas1 ada8: 3815447MB (7814037168 512 byte sectors)
Oct 28 15:03:51 freenas1 ses0: ada8,pass9 in 'Slot 04', SATA Slot: scbus8 target 0
Oct 28 15:04:15 freenas1 ahcich17: Timeout on slot 15 port 4
Oct 28 15:04:15 freenas1 ahcich17: is 00000000 cs 00800004 ss 00808804 rs 00808804 tfd 50 serr 00000000 cmd 00730317
Oct 28 15:04:15 freenas1 ahcich17: ... waiting for slots 00800804
Oct 28 15:04:15 freenas1 ahcich17: Timeout on slot 11 port 4
Oct 28 15:04:15 freenas1 ahcich17: ... waiting for slots 00800004
Oct 28 15:04:15 freenas1 ahcich17: Timeout on slot 2 port 4
Oct 28 15:04:15 freenas1 ahcich17: ... waiting for slots 00800000
Oct 28 15:04:15 freenas1 ahcich17: Timeout on slot 23 port 4
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): READ_FPDMA_QUEUED. ACB: 60 08 90 74 28 40 04 01 00 00 00 00
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): CAM status: Command timeout
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): Retrying command
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): READ_FPDMA_QUEUED. ACB: 60 08 48 c7 1a 40 f7 00 00 00 00 00
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): READ_FPDMA_QUEUED. ACB: 60 08 d0 d0 70 40 f7 00 00 00 00 00
Oct 28 15:04:15 freenas1 (ada21:ahcich17:0:4:0): READ_FPDMA_QUEUED. ACB: 60 08 e0 74 73 40 d1 00 00 00 00 00
Anyway I can solve this? Or the data is gone?
Thanks!
Joerg
hervon
WD40EFAX = SMR. Search forums. Big issue.
alterfritz72
Thanks, heard about that one, but I was thinking this is more about replacing failed disk - not with a freshly created pool...
Not at the time you create the (empty) pool, but whenever you start with big transaction groups... something like:
does that help? anyone tried?
No, firmware can't turn an SMR disk into CMR (or WD would have simply offered that to all the folks who put in for RMA and got new/refurbished CMR disks back instead).
alterfritz72
Still try to recover my data. I can mount the pool in read-only but still see a lot of read errors.
So is there any setting I can make to loader.conf to fix that? Anything I can try?
Top Bottom
