Dwarf Cavendish
- Dec 19, 2017
I started out my NAS with FreeNAS 11.1, using legacy encryption. Due to having a busy life the last couple of years I haven't come around to migrating away from it yet.
Now I was recently confronted with the possibility of having to replace a disk in my pool. And something that I burnt into my memory is: rekey after replacing a disk, otherwise I'll lose access to my pool. It's a procedure I even practiced on a VM years back. So I was just looking into how things now look in the TrueNAS Core UI and it looks like the terminology changed. I think that it's called "Reset Keys" now. So the procedure would then be:
- Hook up replacement disk.
- Boot up my server.
- Unlock the pool using my passphrase.
- Replace the faulty disk in the GUI.
- While resilvering, reset the keys in the GUI.
- Wait for resilvering to finish.
- Shut down server and remove faulty disk.
- Unlock pool using my passphrase and live happily ever after.
