Disk OFFLINE
thereverend
I have just had a disk show up in TrueNAS as OFFLINE. BUT when i boot the system to see if there is a DISK failure in RAID ALL disks are ONLINE and when the system is spun up all disks Init 100%. Any ideas how to get this disk back ONLINE in my TrueNAS? Also drives are now showing some odd signs like "UNHEALTHY "etc.. what is going on?
I just updated this server to the NEWEST release could this be the problem??
Redcoat
Jukebox 1 at 95% - my guess that's unhealthy. Jukebox2 - not enough info to comment.
Post output of zpool status -v
thereverend
I re-installed FreeNAS to see if it would fix Jukebox2 BUT.. How can I get the data back into the pools.. What are the exact steps I need to do to get my data back from Jukebox1 into my FreeNAS. I want to see if FreeNAS has the same issue with Jukebox2..
thereverend
Here is what I got from the one command I tried :
root@freenas[~]# zpool import -D jukebox2
cannot import 'jukebox2': no such pool available
pool: jukebox3
state: UNAVAIL
status: The pool can only be accessed in read-only mode on this system. It
cannot be accessed in read-write mode because it uses the following
feature(s) not supported on this system:
org.zfsonlinux:project_quota (space/object accounting based on project ID.)
org.zfsonlinux:userobj_accounting (User/Group object accounting.)
com.delphix:log_spacemap (Log metaslab changes on a single spacemap andflush them periodically.)
action: The pool cannot be imported in read-write mode. Import the pool with
"-o readonly=on", access the pool on a system that supports the
required feature(s), or recreate the pool from backup.
jukebox3 UNAVAIL unsupported feature(s)
gptid/9b1489e5-7553-11eb-87d8-0022192dbb9c ONLINE
pool: juke5
state: UNAVAIL
juke5 UNAVAIL unsupported feature(s)
gptid/f326ef9b-789c-11eb-9858-0022192dbb9c ONLINE
pool: jukebox2
state: UNAVAIL
jukebox2 UNAVAIL unsupported feature(s)
gptid/871f03f2-7553-11eb-87d8-0022192dbb9c ONLINE
pool: jukebox4
state: UNAVAIL
jukebox4 UNAVAIL unsupported feature(s)
gptid/982855be-7631-11eb-918c-0022192dbb9c ONLINE
pool: jukebox1
state: UNAVAIL
It cut it off but hoping you guys can help with this info that I have supplied above.
Thanks in advance.
Alecmascot
You seem to have a single disk pool ?
Is that set up through a RAID card ?
I see this same error across most of the pools here... are you booting back to FreeNAS 11.3 after a TrueNAS 12 upgrade where you updated your pools?
Redcoat
Did you use TrueNAS Scale by any chance, and not TrueNAS?
And please post the output of zpool status -v to provide a better picture of the overall situation.
thereverend
Yes I am booting back into Freenas after I did the TrueNAS upgrade. BUT completely re-installed FREENAS as it never had any problems. It's not set up like a dual boot or anything.
Redcoat
Yes they are set up as single drives in raid and in the FreeNAS.
I guess this is where the problem is. Your raid card isn't acting as an HBA and passing the drives through to FreeNAS, it appears.
Please describe your hardware, in particular the drives, the "raid" card and the motherboard. I note the earlier post about USB drives.
You have upgraded your pool features to a level that can't be used in FreeNAS anymore. You need to install TrueNAS to use your pools again.
You also need to look at the points from @Redcoat
thereverend
Thank you for all the help. I had some help the other day. How we got it back was to
mount the drive as READ ONLY and then COPY the 2TB of data to a POOL we made in FREENAS.
just wanted to let everyone know how I was able to get at least SOME of my data back off that 1 drive.
Flatron
Perdoe-me por postar meu problema em seu POST. Estou tentando há horas criar um post e não consigo, só recebo uma mensagem de análise.
Eu tenho 5 discos em meu servidor TrueNAS.
Disco 0 (160 GB) = Disco de inicialização FreeNAS
Disco 1 (4 TB) = Pool de armazenamento
Disco 2 (2tB) = Pool de armazenamento
Disco 3 (1 TB) = Pool de armazenamento
Disco 4 (1 TB) = Pool de armazenamento
Hoje (20/09) notei uma falha ao copiar os arquivos para o NAS. Eu acessei o FreeNAS e notei que um disco estava offline. Com a opção "Exportar / Desconectar" nas opções.
Sou novo no FreeNAS. Pesquisei por 2 horas como colocar meu disco online e não consegui. Talvez eu tenha feito errado, eu fiz assim:
No Freenas web (navegador) fui em "Shell" e digitei:
zpool online NAS3 (nome do meu disco 3, que estava offline). A mensagem não foi encontrada. Se eu digitar zpool status, o disco 3 não aparecerá. Em "armazenamento - discos", meu disco 3 aparece. No Setup (BIOS) do meu servidor, o disco 3 também aparece.
Reiniciei meu servidor várias vezes e meu disco 3 não fica online.
Invertei a ordem dos cabos SATA do servidor, sem sucesso.
Então decidi desconectar o disco 3 do servidor, removi os dados SATA e o cabo de alimentação e liguei o servidor Freenas novamente. Para minha surpresa, OUTRO DISCO estava off-line, o Disco 1 (4 TB) também está aparecendo como "off-line" agora.
Eu reconectei os discos rígidos com o cabo SATA e reiniciei o servidor FreeNAS, meu disco 3 que já estava offline, permanece offline e agora o disco 1 também está offline.
Não sei o que fazer, passei 2 dias configurando o servidor FreeNAS para funcionar e já estou arrependido de ter trocado meu antigo servidor Windows Server para compartilhamento de arquivos.
Você pode ajudar este homem desesperado? Obrigado!
