klyneshouse
- Aug 25, 2015
I can't say exactly when this happened but i first noticed today after 11.2-U2.1 upgrade,
the descriptions, settings for HDD standby, and Advanced power management settings for 4 of my 6 disks (raidZ2) were blanked out /reset.
While da1 & da5 were left totally alone.
Nothing different about the disks, as all 6 are the same, and running uneventful for 3+ years.
This was not so alarming, and probably would be unnoticeable for most others, but i also noticed the same 4 disks were also removed from the 2 smart tests.
So it might be worth confirming all your pool disks are still checked for scheduled smart testing.
In viewing the saved config file made just prior to the upgrade, it seems to contain the missing descriptions.
Device Model: ST3000VN000-1HJ166
Firmware Version: SC60
Also mostly still using the old web interface - fwiw.
