Disable restore option for shadow copies SMB
chuck32
is there a way to prevent users from using the restore option on smb shares?
From what I read it's best to open the snapshot and copy the file you need rather than restoring.
For security purposes I would like to ideally finetune the share in a way, that users may be able to browse snapshots and copy files from there, but they should not be able to click restore. I do not want someone to accidentally restore a folder or the toplevel of the shared dataset. Depeding on the snapshot retention policy I fear that may lead to data loss if not caught.
The shares are provided by a TrueNAS-SCALE-23.10.0.1 instance, the clients are all win 11 machines.
Thanks!
chuck32
This is the context menu in Windows for better understanding.
