ChrisChros
- Nov 24, 2018
is there a way to disable https on the nextcloud plugin. I run nextcloud in my privat environment with no direct access from the inet. Only over my VPN connection I can access nextcloud from external.
Since the update to 23.0.2 I am not able to open the webpage from NC with Chrome. I always receive a NET::ERR_CERT_INVALID failure.
So I would like to disable https, also I am not really familiar with SSL and facing other problems e.g. backup access from my opnsense to nextcloud because of wrong ssl certificate.
Thanks for you help.
