Hello Community,
I am running TrueNAS-12.0-U6 on a Ryzen 1400X and 8GB ECC RAM with a RAIDZ2 consisting of four 6TB drives. The pool is restricted to the local network, so not accessible through the internet. I have two plugins installed: plex and NextCloud.
Currently, I am trying to make the best use of the NextCloud-Plugin. Nextcloud itself is running, I can use the webinterface as well as the Android app to sync my photos (when I am connected to my home wifi of course).
My ultimate goal now is to mount my NextCloud folder(s) to my Windows-PC via webDAV.
Applying the usually recommended routine (mounting through windows explorer or cmd), I receive a system error 1244.
The usual google search brought me to this website (in German): https://www.allerstorfer.at/windows-10-selbst-signiertes-ssl-zertifikat-importieren/
stating, that addresses with self-signed certificates do not work with webDAV unless the certificate is manually installed through the Windows Certificate Manager.
Therefore, I downloaded the certificate Chrome shows me when entering the NextCloud through the webinterface and installed that (certificate is the localhost certificate issued by the TrueNAS system) - without any effect.
So I tried to create and implement a self-created and self-signed certificate following these two guides (independently from each other):
					www.truenas.com
					www.youtube.com
Both ended with the same result - nothing changed. A reason might be that when restarting the NextCloud-plugin, the nextcloud.conf file is reset to its initial state.
Do you know anything else I could try to make it run?
Please let me know if and what kind of additional input you need to help me.
Have a nice evening!
Nextcloud SSL
Just wondering how to setup a self signed SSL certificate for Nextcloud. Am only 13 so have very limited experience. Any help or guidance would be appreciated. Am using no-ip for ddns. Running freenas 11.
				Install Nextcloud Plugin on TrueNAS CORE & Enforce HTTPS with a Self-Signed Certificate
Want to secure Nextcloud on TrueNAS CORE with HTTPS encryption? In this step-by-step guide, I’ll show you how to:✅ Install the Nextcloud Plugin on TrueNAS...
