disable commandline/console alerts
Grinas
I have a failed drive that i am waiting for a replacement to come but in the mean time i am getting alerts regularly when accessing truenas via SSH.
I do a lot of work on containers and access them via the shell so wondering is it possible to disable these as its making it a nightmare to work in the commandline.
here is an example of an alert
2024 Feb 12 19:45:43 truenas Device: /dev/sdd [SAT], 6 Currently unreadable (pending) sectors
Grinas
actually the drive that failed was replaced by the spare.
the drive that is showing Currently unreadable (pending) sectors is new.
Here are the smartctl results
smartctl -a /dev/sdd
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.63-production+truenas] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     ST10000VE001-3BX101
Serial Number:    WP00PJ2F
LU WWN Device Id: 5 000c50 0edac4c7b
Firmware Version: EV01
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5319
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Feb 13 08:57:12 2024 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  559) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 862) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   081   064   044    Pre-fail  Always       -       126566017
  3 Spin_Up_Time            0x0003   091   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       14
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   085   060   045    Pre-fail  Always       -       307503620
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       4166
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       13
 18 Unknown_Attribute       0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   066   066   000    Old_age   Always       -       34
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       8590131203
190 Airflow_Temperature_Cel 0x0022   072   040   000    Old_age   Always       -       28 (Min/Max 24/30)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1901
194 Temperature_Celsius     0x0022   028   060   000    Old_age   Always       -       28 (0 24 0 0 0)
197 Current_Pending_Sector  0x0012   100   085   000    Old_age   Always       -       6
198 Offline_Uncorrectable   0x0010   100   085   000    Old_age   Offline      -       6
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       4023 (20 193 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       105942459784
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       200985229471
SMART Error Log Version: 1
ATA Error Count: 46 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 46 occurred at disk power-on lifetime: 884 hours (36 days + 20 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: WP at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  61 00 00 ff ff ff 4f 00  31d+02:23:11.265  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  31d+02:23:10.264  WRITE FPDMA QUEUED
  61 00 10 30 01 00 40 00  31d+02:23:09.825  WRITE FPDMA QUEUED
  61 00 08 00 43 03 40 00  31d+02:23:09.752  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  31d+02:23:09.680  WRITE FPDMA QUEUED
Error 45 occurred at disk power-on lifetime: 884 hours (36 days + 20 hours)
  61 00 00 ff ff ff 4f 00  31d+02:23:08.553  WRITE FPDMA QUEUED
  61 00 08 00 43 03 40 00  31d+02:23:08.553  WRITE FPDMA QUEUED
  61 00 10 ff ff ff 4f 00  31d+02:23:08.553  WRITE FPDMA QUEUED
  60 00 80 ff ff ff 4f 00  31d+02:23:08.553  READ FPDMA QUEUED
Error 44 occurred at disk power-on lifetime: 879 hours (36 days + 15 hours)
  61 00 80 ff ff ff 4f 00  30d+21:03:16.383  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+21:03:15.862  WRITE FPDMA QUEUED
  61 00 80 ff ff ff 4f 00  30d+21:03:15.857  WRITE FPDMA QUEUED
  61 00 80 ff ff ff 4f 00  30d+21:03:15.856  WRITE FPDMA QUEUED
  61 00 80 ff ff ff 4f 00  30d+21:03:15.855  WRITE FPDMA QUEUED
Error 43 occurred at disk power-on lifetime: 877 hours (36 days + 13 hours)
  61 00 00 ff ff ff 4f 00  30d+19:21:04.056  WRITE FPDMA QUEUED
  61 00 08 00 43 03 40 00  30d+19:21:03.525  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+19:21:03.055  WRITE FPDMA QUEUED
  61 00 10 ff ff ff 4f 00  30d+19:21:03.034  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+19:21:02.678  WRITE FPDMA QUEUED
Error 42 occurred at disk power-on lifetime: 877 hours (36 days + 13 hours)
  61 00 08 00 43 03 40 00  30d+19:15:20.901  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+19:15:20.551  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+19:15:19.910  WRITE FPDMA QUEUED
  61 00 00 ff ff ff 4f 00  30d+19:15:19.731  WRITE FPDMA QUEUED
  60 00 80 ff ff ff 4f 00  30d+19:15:19.461  READ FPDMA QUEUED
# 1  Conveyance offline  Completed without error       00%        68         -
# 2  Extended offline    Completed without error       00%        13         -
