Directory services over plain Samba
larynx
I currently have a box running FreeNAS 9.10, the box is being used as a file server only with files served using Samba to less than 10 workstations in a Windows-only (7,8,10) space.
I was wondering if it would be worth enabling any sort of directory services on the box with either Active Directory or OpenLDP (or something else) so the box can be used for user authentication instead of the local accounts the workstations have at the moment. I've seen plenty of posts about directory services (AD specifically) not functioning correctly or periodically stopping on FreeNAS and I was wondering if it's worth the hassle.
Thank you
mattbbpl
Active Directory can be a pain for the novice.
Do you have reason to block access? If not, I'd just avoid it.
Heck, even if you're concerned about guests accessing it, it would probably be simpler to set up the guest network on your router to segregate that traffic from your personal traffic (which I would recommend anyway, for various reasons).
larynx
The only thing I need to worry about is authenticated users on the network accessing files they don't have permissions to read/write. Right now it's being taken care of by Samba but I wondering if there would be an advantage to using directory services for that
Only if you have a lot of users.
anodos
Sambassador
I'd say around 20-30 users is where I'd start seriously looking into AD. You don't need AD to secure a samba server.
With your size, an easier time-saver would be (if you have relatively standardized hardware) to
1) create a clean windows install with all required applications, local group policies set up, and local admin accounts.
2) use sysprep to put it in a generalized state
3) image the disk using clonezilla or a similar tool.
4) reimage computers liberally
These items will get you a lot of the security benefits of a more complex windows environment, and knock a few of the SANs top 20 off the to-do list.Just make sure your images work.
I'd write more, but typing on a mobile phone is too annoying.
