Difference Between Sysctl and Jail.conf
STREBLO
I was looking to make a jail for a repo using synth and he mentions in the readme putting the folloing in a jail.conf
enforce_statfs=0
allow.mount
allow.mount.nullfs
allow.mount.tmpfs
allow.mount.devfs
I haven't heard of a jail.conf before. Can these just be added to the sysctl settings in the gui? Or are jail.confs completely different?
STREBLO
Sysctls in the gui just change the rc.conf though right? In FreeNAS there's no jail.conf, right?
D
dlavigne
Guest
Correct that there is no jail.conf being used by FreeNAS.
STREBLO
So can I just add this to the sysctls then?
enforce_statfs=0
allow.mount
allow.mount.nullfs
allow.mount.tmpfs
allow.mount.devfs
D
dlavigne
Guest
Yes, but note that the sysctl names are different:
sysctl -a|grep statfs
security.jail.param.enforce_statfs: 0
security.jail.enforce_statfs: 2
sysctl -a | grep allow.mount
security.jail.param.allow.mount.zfs: 0
security.jail.param.allow.mount.tmpfs: 0
security.jail.param.allow.mount.procfs: 0
security.jail.param.allow.mount.nullfs: 0
security.jail.param.allow.mount.fdescfs: 0
security.jail.param.allow.mount.devfs: 0
security.jail.param.allow.mount.: 0
STREBLO
Thanks!
