I have the following error on my TrueNAS : Device: /dev/ada0, 8 Currently unreadable (pending) sectors.
I looked at some posts and I can't find a solution to my problem.
I'm not an expert at all but I've run all the tests I know and I have no error. The drives are less than a year of usage.
Here's the result of my "smartctl -a /dev/ada0" :
Can someone help me with that ?
=== START OF INFORMATION SECTION === Model Family: Seagate BarraCuda 3.5 (SMR) Device Model: ST8000DM004-2U9188 Serial Number: ZR14D2R7 LU WWN Device Id: 5 000c50 0e6969e38 Firmware Version: 0001 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Jul 6 10:24:23 2023 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 994) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x30a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 076 062 006 Pre-fail Always - 36205144 3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 24 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 083 060 045 Pre-fail Always - 190355123 9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2245h+21m+20.203s 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 24 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 053 050 040 Old_age Always - 47 (Min/Max 40/49) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 100 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 108 194 Temperature_Celsius 0x0022 047 050 000 Old_age Always - 47 (0 21 0 0 0) 195 Hardware_ECC_Recovered 0x001a 076 064 000 Old_age Always - 36205144 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 8 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 8 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2239h+09m+10.381s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 4754657132 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 5890401016 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 2233 - # 2 Extended offline Aborted by host 30% 2216 - # 3 Short offline Completed without error 00% 2200 - # 4 Short offline Completed without error 00% 2198 - # 5 Extended offline Completed without error 00% 2012 - # 6 Short offline Completed without error 00% 1981 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
