One of my drives in my freenas server appears to have had some problems and has been kicked out of the pool. I'm trying to run smartctl on it but I can't find it.
Hardware:
1. Motherboard: ASUS P9D WS
2. CPU: Intel i3-4150
3. RAM: 16GB ECC
4. Hard Drives: 1x USB used for OS (see below)
6x 2TB ST2000DM001-1ER164 Samsung drives
- all 6 samsung drives are directly plugged into the motherboard sata ports
5. Build: FreeNAS-9.3-STABLE-201504100216 (with all current zfs flags installed)
6. ZFS Pool: RAIDZ2
I saw that there was an alert in the GUI interface so I ran zpool status and got:
I then ran zpool clear and rebooted, and now I get:
Next step would be to run smartctl commands on it, but I can't find the disk anymore (should be 6 drives, on on scbus5 I imagine):
and
Is the disk totally dead, or do I need to take it out and work on it in another computer? The data is backed up elsewhere as well.
Hardware:
3. RAM: 16GB ECC
6. ZFS Pool: RAIDZ2
[root@freenas] ~# zpool status pool: Base state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 0 in 0h28m with 0 errors on Mon Apr 13 20:08:13 2015 config: NAME STATE READ WRITE CKSUM Base DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 gptid/335a1344-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/339a8a90-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/33dab725-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/3431f09b-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/34747be3-3d51-11e4-875a-40167e36b520 FAULTED 0 11 0 too many errors gptid/34c6d71d-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h4m with 0 errors on Tue Apr 14 00:04:27 2015 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/66f468c1-8436-11e4-a43c-40167e36b520 ONLINE 0 0 0 errors: No known data errors
[root@freenas] /dev# zpool status pool: Base state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: http://illumos.org/msg/ZFS-8000-2Q scan: scrub repaired 0 in 0h28m with 0 errors on Mon Apr 13 20:08:13 2015 config: NAME STATE READ WRITE CKSUM Base DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 gptid/335a1344-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/339a8a90-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/33dab725-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 gptid/3431f09b-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 5899279064343081067 UNAVAIL 0 0 0 was /dev/gptid/34747be3-3d51-11e4-875a-40167e36b520 gptid/34c6d71d-3d51-11e4-875a-40167e36b520 ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h4m with 0 errors on Tue Apr 14 00:04:27 2015 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/66f468c1-8436-11e4-a43c-40167e36b520 ONLINE 0 0 0
[root@freenas] /dev# camcontrol devlist <ST2000DM001-1ER164 CC43> at scbus1 target 0 lun 0 (pass0,ada0) <ST2000DM001-1ER164 CC43> at scbus2 target 0 lun 0 (pass1,ada1) <ST2000DM001-1ER164 CC43> at scbus3 target 0 lun 0 (pass2,ada2) <ST2000DM001-1ER164 CC43> at scbus4 target 0 lun 0 (pass3,ada3) <ST2000DM001-1ER164 CC43> at scbus6 target 0 lun 0 (pass4,ada4) <SanDisk Cruzer Blade 1.27> at scbus8 target 0 lun 0 (pass5,da0)
and
[root@freenas] /dev# ls -l | grep ad lrwxr-xr-x 1 root wheel 4 Apr 19 18:36 ad10@ -> ada3 lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad10p1@ -> ada3p1 lrwxr-xr-x 1 root wheel 10 Apr 19 18:37 ad10p1.eli@ -> ada3p1.eli lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad10p2@ -> ada3p2 lrwxr-xr-x 1 root wheel 4 Apr 19 18:36 ad14@ -> ada4 lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad14p1@ -> ada4p1 lrwxr-xr-x 1 root wheel 10 Apr 19 18:37 ad14p1.eli@ -> ada4p1.eli lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad14p2@ -> ada4p2 lrwxr-xr-x 1 root wheel 4 Apr 19 18:36 ad4@ -> ada0 lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad4p1@ -> ada0p1 lrwxr-xr-x 1 root wheel 10 Apr 19 18:37 ad4p1.eli@ -> ada0p1.eli lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad4p2@ -> ada0p2 lrwxr-xr-x 1 root wheel 4 Apr 19 18:36 ad6@ -> ada1 lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad6p1@ -> ada1p1 lrwxr-xr-x 1 root wheel 10 Apr 19 18:37 ad6p1.eli@ -> ada1p1.eli lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad6p2@ -> ada1p2 lrwxr-xr-x 1 root wheel 4 Apr 19 18:36 ad8@ -> ada2 lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad8p1@ -> ada2p1 lrwxr-xr-x 1 root wheel 10 Apr 19 18:37 ad8p1.eli@ -> ada2p1.eli lrwxr-xr-x 1 root wheel 6 Apr 19 18:36 ad8p2@ -> ada2p2 crw-r----- 1 root operator 0x73 Apr 19 18:36 ada0 crw-r----- 1 root operator 0x7f Apr 19 18:36 ada0p1 crw-r----- 1 root operator 0xaf Apr 19 18:37 ada0p1.eli crw-r----- 1 root operator 0x81 Apr 19 18:36 ada0p2 crw-r----- 1 root operator 0x75 Apr 19 18:36 ada1 crw-r----- 1 root operator 0x83 Apr 19 18:36 ada1p1 crw-r----- 1 root operator 0x93 Apr 19 18:37 ada1p1.eli crw-r----- 1 root operator 0x85 Apr 19 18:36 ada1p2 crw-r----- 1 root operator 0x77 Apr 19 18:36 ada2 crw-r----- 1 root operator 0x87 Apr 19 18:36 ada2p1 crw-r----- 1 root operator 0x95 Apr 19 18:37 ada2p1.eli crw-r----- 1 root operator 0x89 Apr 19 18:36 ada2p2 crw-r----- 1 root operator 0x79 Apr 19 18:36 ada3 crw-r----- 1 root operator 0x8b Apr 19 18:36 ada3p1 crw-r----- 1 root operator 0x97 Apr 19 18:37 ada3p1.eli crw-r----- 1 root operator 0x8d Apr 19 18:36 ada3p2 crw-r----- 1 root operator 0x7b Apr 19 18:36 ada4 crw-r----- 1 root operator 0x8f Apr 19 18:36 ada4p1 crw-r----- 1 root operator 0x99 Apr 19 18:37 ada4p1.eli crw-r----- 1 root operator 0x91 Apr 19 18:36 ada4p2 lrwxr-xr-x 1 root wheel 11 Apr 19 18:36 dumpdev@ -> /dev/ada0p1
