schoolpost
- Feb 14, 2018
Is there a stat or measurement you can refer to in FreeNas that will tell you your drives health?
I'm swapping drives out of my RAID Z3 10 drive pool for larger ones and noticed my most recent resilver took much longer than usual.
( ~ 50MB/s I usually see about double during my resilvers )
My initial thought is that maybe an existing drive in the pool is lagging behind and it might be due to imminent failure.
So I want to swap out the drive with the least health in the pool as I'm migrating to larger disks.
What is the best way to determine a drive's health in FreeNas and how does one go about it?
Thanks
Thanks
