Hi All,
Since the last post about R710 was more than a year ago. I'm here to share my experience of setting up a Dell R710 + H200 (H200i to be specific) controller with 6x 3TB HDDs in case anyone else stumple across these hardwares and wanted some 'latest' info. Since these hardwares are quite cheap for home use purpose IMO.
The primary goal is to setup a NAS in Home network, secondary goals are few various VMs for services and docker containers etc. for sysadmin & software developments
Was initially only able to install Proxmox and run TrueNAS as VM with attached disk.
Disk size was limited to 2.2TB due to lack of firmware update to the H200.
TrueNAS CORE 12.0 U7 was looping with "root mount waiting for: CAM" message when booting up the installer.
Managed to (bare metal) install and setup zfs pool with below steps:
This is still under experiment, hopefully I won't run into stability issue.
I'll update this post when there's any info gap/clarification from internet search that's worth sharing.
My next step is to assess if it is really neccessary to flash the H200 to IT mode.
Hope this may help a few souls from banging their head.
Thanks for reading.
Cheers.
- Setup bootable FreeDOS USB (used Rufus for this).
*Some USB stick works and some doesn't. For those that doesn't will hang at initial boot screen, and for those that works, you'll be able to enter BIOS setup etc. with function keys.
- Expanded and copied files downloaded from Dell (below #3 & #4) to it.
- BIOS boot to FreeDOS.
- Flashed BIOS to 6.6.0 (url).
Ran the exe in FreeDOS and reboot, it didn't take long.
- Flashed H200 to 07.03.06.00, A10 (url).
Ran the flash.bat, it took a little while and reboot.
*Not sure if it matters, I flashed it when it's plugged in the non-integrated PCIe slot.
- Set to UEFI boot.
- Install away.
- TrueNAS is able to see all disks in 3TB.
Thanks for reading.
Cheers.
