Hi all,
So I have had scale running great for the last couple of months, tonight I noticed the fans had ramped up to louder than normal. After a bit of investigating I might of narrowed it down to one fan. I removed it and it’s calmed down a bit but I’m getting a lot of fan errors on the notifications. I didn’t realise that truenas would have direct feedback from the onboard sensors, would this be true? So I’m getting errors on truenas saying I’m having fan issues?
I also noticed on the monitor I attached that when the system boots and on its console, 1-9 commands. I noticed some random stuff popping up then it goes back to the 1-9 options. Is it a case that whenever it’s doing something it pops up then goes back the the options. I just thought that it sat at that menu permanently.
Sorry bout the long and mixed questions, maybe someone can help? Is there anything I should look into first??
Thanks
- Fan Fan7B Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan7A Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan7A Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan Redundancy Asserted Redundancy Lost.
- Fan Fan6A Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan6A Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan6B Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan6B Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Physical Security Intrusion Deasserted General Chassis intrusion ().
- Physical Security Intrusion Asserted General Chassis intrusion ().
- Fan Fan6A Deasserted Lower Critical going low : Reading 9240 < Threshold 720 RPM.
- Fan Fan6A Deasserted Lower Non-critical going low : Reading 9240 < Threshold 840 RPM.
- Fan Fan6B Deasserted Lower Critical going low : Reading 8160 < Threshold 720 RPM.
- Fan Fan6B Deasserted Lower Non-critical going low : Reading 8160 < Threshold 840 RPM.
- Fan Fan7B Deasserted Lower Critical going low : Reading 960 < Threshold 720 RPM.
- Fan Fan7A Deasserted Lower Critical going low : Reading 1080 < Threshold 720 RPM.
- Fan Fan7A Deasserted Lower Non-critical going low : Reading 1080 < Threshold 840 RPM.
- Fan Fan Redundancy Asserted Fully Redundant.
- Fan Fan7B Deasserted Lower Non-critical going low : Reading 8400 < Threshold 840 RPM.
- Fan Fan4A Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan4A Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan5A Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan5A Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan5B Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan5B Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
- Fan Fan4B Asserted Lower Non-critical going low : Reading 0 < Threshold 840 RPM.
- Fan Fan4B Asserted Lower Critical going low : Reading 0 < Threshold 720 RPM.
Thanks
